this is a new one on me. i am at a loss to figure this out.
for 2 years i have been using vegas 4 to convert the audio in .dv files (and .avi files that are DV files) into .ac3 files. this has always worked flawlessly for over 1500 files.
however the last 2 files i converted are roughly 1 second out of sync. the audio is about 1 second ahead of the video. the first second is cut off from the audio.
i spent a few hours today trying to figure this out. i am almost positive the problem lies in vegas. basic troubleshooting indicates that files created 2 weeks ago and before will mux correctly in tmpgenc and be in sync. files created within the last 9 days are 1 second out of sync when muxed in tmpgenc. (i only mux to check the compressed files before i toss the .avi)
i have no idea how to deal with this.
somehow i did get one file to mux in sync after several tries re-rendering the audio in vegas. i was unable to repeat this. repeated attempts were out of sync.
i havent changed any preferences in vegas since i installed it 2 years ago.
the only change i have made to the pc is adding ffdshow, roughly a week ago. i do not know if this is causing the problem or not but due to the time the problem showed up it seems possible. i will uninstall it and re-render the out of sync audio.
the preference in vegas "ignore external dv codecs" is checked.
any advice for this mac guy?
edit: i must add that the original dv files are in sync when played.
the audio and video are in sync when played in vegas.
gspot says the dv files is: video 29.970. audio 48k 16bit
Output Size of PAL VCD Rendered In Sony Vegas Pro 10 Is Too Huge
By LeHuoXuan in forum Authoring (VCD/SVCD)Replies: 8Last Post: 28th Feb 2011, 21:40 -
Sony Vegas 9.0 Has no audio on rendered file
By cowombat in forum Newbie / General discussionsReplies: 3Last Post: 25th Oct 2009, 08:02 -
Vegas AVI 2gig rendered file size limit
By Gargalash in forum EditingReplies: 2Last Post: 17th Nov 2008, 09:12 -
Sony DVD-Architect won't load markers in mpeg file rendered in Vegas
By mltwitz in forum Authoring (DVD)Replies: 1Last Post: 25th Jan 2008, 10:01 -
What soft can mux/demux Vegas rendered mpg's?
By Srivas in forum EditingReplies: 8Last Post: 3rd Dec 2007, 05:21
