I did say there was other times it was useful, silent films and other nonstandard frame rates of course.Originally Posted by manono
As far as sound quality, no PAL film I've ever converted has sounded all that great to begin with. The new high quality stuff is generally available in NTSC. And oftentimes PAL DVDs have MPEG audio which has to be converted anyway. I don't suppose ffmpeg encodes AC3 any better than BeSweet? I've never tried to compare.
Here's why I can see the stutter. On an NTSC interlaced TV, two matched fields from one film frame display for 33.37ms. If it has a repeated field (pulldown) it shows for half again as long, 50.05 ms. We'll call these S and L for "short" and "long" frames. This gives DGPulldown the choice of those two frame durations for every frame of the movie, and that's why it can get any overall speed from 19.98 to 29.97, using combinations of those.
Normal 23.976>29.97 film pulldown displays like this:
S L S L S L S L S L S L ... continuously. The long frame happens about 12 times per second. This is only barely noticeable and everyone is used to it because it's always been done that way.
19.98 would be all long frames:
L L L L L ... which would be even smoother than regular film pulldown.
But when you go 25>29.97 you get:
S L S L S S L S L S S L S L S S ....
The two "short" (i.e. fast) frames in a row happen about 5 times per second, which is slow enough for me to notice. It's not that bad and I've seen much worse motion artifacts caused by ignorance/stupidity and multiple conversions, but just that and the pitch shift are enough to convince me to slow it down to the correct speed. I guess it comes down to preference.
Here's a pitch shift example: a clip from The Final Countdown.
finalntscclip.mp3
finalpalclip.mp3
These are from the retail DVDs, both versions of which I own, not something I've manufactured.
Results 31 to 33 of 33
So, you're saying that jerky 2 3 2 3 2 3 doesn't bother you because you're used to it, but 2 3 2 3 2 2 3 does bother you because it's a new and different kind of jerkiness?
Neither bothers me much as I'm also used to it. When I look for it, like during a slow pan, I can see it, so I don't look for it. What does bother me though, is blending, which is only too common as a result of using the PAL master for the NTSC DVD. And they're never as clear and detailed as they might be had they taken care to prepare a proper NTSC master. I have some PAL friends that hate the NTSC jerkiness, I guess because they're not used to it. And maybe because they are used to it, the PAL audio speedup doesn't seem to bother them much.
Maybe at some point in the future we'll have TVs with adjustable refresh rates, as computer monitors do, something like those Pioneer sets that can output 72 Hz, and play Telecined Film as 3 3 3 3.
So I apologize. When you said that DGPulldown made a DVD play jerky, I thought it was resulting from something you did wrong at some point during the conversion. -
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19
