I have a few VHS VCR tapes that I would like to capture to VCD soon. I am confused as to the capture cards I would use. I might at some point like to edit the video with captions, and effects etc.
What card will allow me to capture? I currently have a Asus V7100 card which only supports Tv Out. Is the Asus V7700 a better option or would a cheap card suffice?
I'd recommend a WinTV card...You can capture to MPEGI or MPEG-2 with that card if you use a program called CinePlayer DVR. You can also capture as high as 640*480+ with the card using VirtualDub, which is no doubtfully explained in an artical on this site. So, i'd get the WinTV. Unless you feel that your Video Card is aging and you want to get a new Video Card, too. In that case i would go to the ATI All-in-Wonder Radeon, i've heard lots of good things about it. However i hear that ATI's and Athlons dont go good together..but this is, just a rumour, and if you ask around sombody will be sure about it. Best of luck!
If I knew everything, I wouldn't be here....
How do I capture my VHS tapes to DVD
By tfoster in forum Newbie / General discussionsReplies: 4Last Post: 26th Jan 2011, 12:57 -
Dumb question on improving video for capture from VHS tapes
By lewist57 in forum Capturing and VCRReplies: 13Last Post: 2nd Jul 2010, 12:26 -
Want to get home video pal VHS onto my pc HDD, recomended capture card?
By ha9981 in forum Capturing and VCRReplies: 6Last Post: 26th Mar 2009, 15:34 -
Can't Capture VHS Tapes+video Compression list Is Empty
By mikidream in forum Capturing and VCRReplies: 4Last Post: 21st Apr 2008, 12:27 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
