I have on my pc two partitions with a winxp pro installation on it. Both make naturally use of the same hardware: P4 3.0 ghz and 1024 mb memory and a NEC double layer 3520. Also a dvd player from pioneer 106S.
When i put a dvd in the drive and open disc in dvdshrink newest version then he analyses the dvd. When he does this there is a data speed: approxamaly: 2100-2800 kb/s.
On the other XP installation it is on the same dvd: 4900 kb/s: that is twice as fast!!
THis is also when the DVD is beiing ENCODED, the same speed!
Can this be a setting? Is it the partition who can make the difference in speed?
A second pc AMD 1000 mhz and 512 mb memory is doiing it also with 2500 kb/s. How is this possible?
Results 1 to 1 of 1
Ripping speed for dvd-r
By vcd4me in forum DVD RippingReplies: 10Last Post: 22nd Apr 2011, 06:45 -
DVD Ripping...DVDShrink, DVD Fab question...
By nharikrishna in forum DVD RippingReplies: 9Last Post: 28th Feb 2011, 06:08 -
DVD Fab v/s AnyDVD Ripping Speed
By wulf109 in forum Blu-ray RippingReplies: 0Last Post: 25th Mar 2010, 14:04 -
AutoGK - ripping the DVD gets out audio out of sync - okay after DVDShrink
By lchiu7 in forum DVD RippingReplies: 7Last Post: 8th Dec 2009, 00:06 -
Good DVD ripping software? Currently using DVDShrink.
By Hank Kinsley in forum Authoring (DVD)Replies: 9Last Post: 11th Oct 2009, 10:20
