Hey guys,
wondering if someone can give me some advice. I have some images of DTS audio CDs and I want to put them on - a few at a time - on DVD. Whilst keeping the DTS obviously. I want to have menu pages where - preferably, I can choose to play the whole CD or individual tracks.
I use Ulead DVD Workshop 2.0
Is it as simple as converting the image into a wav? How do I make sure I keep the DTS and does DVDW2.0 support DTS? I've never tried.
With thanks with any suggestions you might have,
Pepper.
DVDW2.0 does not support DTS
CD audio DTS is not the same as DVD audio DTS and would require a re-encode ...
you could make a audio dvd or a dvd with dts -- either way would require some expensive encoders .. or just leave them as audio cd's ...
i hope you have the originals - as what you are describing might be considered warez (maybe not in Taiwan though - dont know) .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
0 run Exact Audio Copy, then rename *.wav to *.dts
1 run foobar2000 -- Conver to 6 ch wave file
2 run ssrc convert to 48KHZ
3 RUN BeSweet -- convert 6ch wave to dts ( need Surcode DVD Pro for DTS Encoder )
4 author dvd with dvd-lab
You can see here but you need know chinese!
http://www.bnuavpress.com/dvbbs/dispbbs.asp?boardID=15&ID=41&page=1 -
yes - as i said it requires a re-encode and a $2000 program
since you would be losing so much quality - it is a pointless thing to do really ..
DVD-Audio to Dolby TrueHD or DTS-HD
By greymalkin in forum AudioReplies: 2Last Post: 20th Apr 2011, 12:01 -
Is it still DTS audio if its at 448kb/s on a dvd?
By yoda313 in forum AudioReplies: 8Last Post: 7th Sep 2009, 08:06 -
Authoring a DVD with DTS 5.1 Audio
By wanguy2k in forum Authoring (DVD)Replies: 4Last Post: 12th Sep 2007, 18:52 -
How to convert AVI with DTS audio to DVD
By Jean in forum Video ConversionReplies: 6Last Post: 24th Aug 2007, 02:25 -
Help with DTS 5.1 Audio CDs
By ontherocks in forum AudioReplies: 4Last Post: 20th Aug 2007, 08:22
