Hi Guys,
well I have a HP 9140i Cd writer....whenever I burn a Movie Cd using the HP CD writer software provided with the CD writer..I find that the Complete Movie has Burned on the CD...BUT this VCD Doesnt play On ANY conventional VCD Player....
.....I fail to understand the reason behind this ......can Any body help me Explaining which SOFTWARE I should use to burn my Movie VCD's So that I can Play it on ALL VCD Players....
......Any help is most Welcome........
Reagards,
Nityanand.
I thnk the HP software's movie CD isn't actually a VCD, try VCD Easy from the tools section here or Nero (the first is free, better and easier though
Check the tools section under authoring/burn try em all if you got the time.Some are better than others but id recommend Nero or Winoncd,ezcd creator sucks the big one.I use the Philips VideoCD Toolkit for vcds and nero for non compliant (x)vcds.
I agree with the last post.EZcd creator Sucks AND Blows the big one.Get NERO ! You can burn non-compliant/compliant cd's and can do a crapload of stuff!
