    Jan 2003
    Brazil
    Eventhough the VirtualDubMod can open vob files, it seems it can't serve the audio of those vob files, through the *.vdr files ones, to any encoder. .
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    So demux the audio, or extract to WAV, then use that ???
    ... or try virtualdub-MPEG2 ?
    What audio is in your VOBs ?
    What audio do you want to end up with ?
    If in doubt, Google it.
    Jan 2003
    Brazil
    Ok, but I wish we would not have to waste our time doing this.
    And I guess that the virtualdub-mpeg2 can't open vob files.
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Well, I'm certainly no mind-reader ..... and I can't see your screen from here. So .......
    ... maybe I know a better way to do things, if you could tell your situation in just a little more detail ?
    What do you think is inside VOBs ?
    MPEG-2, perhaps ?
    I wouldn't have recommended it if I didn't think it could do the job
    https://www.videohelp.com/tools?tool=Virtualdub-MPEG2
    Virtualdub mod with MPEG2(SVCD, DVD, VOB) import support.
    ... and I'm only assuming that your first post here was a question, and not just a comment ?
    Jan 2003
    Brazil
    MPEG-2, perhaps ?
    Thanks a lot man. It did work. But now I have another problem. I guess as you know, I have been looking for an dvd author program that could let me add a lot of movies in a same program chains. As you told me, the tmpgenc dvd author does this, but it doesn't handle subtitles and first play movie.
    I was trying the dvdauthorgui, but seems that it doesn't handle wav files, and I only know and have encoder that create wav ones.
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    ffmpeggui, besweet, belight ... the only audio tools you'll ever need, and they're all free
