I've just bought an Archos PMA400. I'm now trying to rip several of my DVD's to avi's to watch on my new player. I'm trying to limit each film rip to 700MB approx (avi). I've had a few goes but I'm not getting any good quality rips. I have some tv shows I downloaded off the web which are 300MB in size. They are 1 hour in duration at a frame rate of something like 650 * 450 (not exact - from memory). The quality of these clips is excellent so I'm thinking the films are twice the duration of the clips of I'm hoping I should be able to get each film to 700MB.
Any tips on what software to use/best settings?
Thanks in advance.
Xvid: 2-pass Variable Bitrate if you want a specific size. Single Pass Quantization mode (constant quality) if you don't.
Originally Posted by junkmalle
Thanks for the info so far guy's. -
What program you use doesn't make any difference in the final size or quality. The codec is doing all the real work. I use VirtualDubMPEG2, Xvid (in quantization mode), and Lame for MP3 audio most of the time. VirtualDubMPEG2 isn't the simplest of programs though.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
[Archos 605] transform from 720p.HD.DVDRip.XviD.AC3 to Archos format ?
By birdwing in forum Portable VideoReplies: 2Last Post: 5th Nov 2009, 23:41 -
DVD to AVI (done) to Divx or xvid
By Grumpy_one in forum DVD RippingReplies: 3Last Post: 16th Mar 2009, 17:28 -
Best DVD to DivX / Xvid avi
By spidey in forum DVD RippingReplies: 6Last Post: 3rd Jul 2008, 14:20 -
Archos 404 & DVR stand vs Archos AV 500 - difference in MPEG-4 recordin
By DavidMcGowan in forum Capturing and VCRReplies: 0Last Post: 4th Aug 2007, 05:49
