Hey,
I’m looking for software that will allow me to add a logo/text to a music video, movie and etc… Let’s sat I want to add **www.videohelp.com** under a video. What software do I need to use?
Amir
Results 1 to 10 of 10
virtualdub or virtualdubmod
freewareI love it when a plan comes together! -
You did not specify what format your music video is in - that would have been useful.
To be slightly more specific, and this answer is more for avi files, you will need VirtualDub plus some of its custom filters (they are the ones that accomplish the functions you describe).
Adding a logo or a permanent text: you might want to use the logo filter
http://neuron2.net/logo/logo.html
It enables you to permanently display a bitmap logo on top of your video
For pute text, you can use the textsub filter for instance (you'll need to create a subtitle file with your text and the subtitle timing, you can use any of the subtitle tools for that, like Subtitle Workshop for instance). -
Guides section
https://www.videohelp.com/guides.php?guideid=714#714If in doubt, Google it. -
one more thing...i have already made the logo with adobe photoshop and i just need to add it to the video..would these software work in this condition too??
If you made your logo in Photoshop and it has a transparent layer, you can save it as a PSD or PNG. You can then use your video editor or Wax2 (free) to overlay the image on top of your video. Wax2 will auto detect alpha channels in a PSD or PNG and make them transparent.
Any good video editor should easily do this, if yours don't then try Wax2.
Text Logo Sub Help
By kenryuakuma in forum SubtitleReplies: 26Last Post: 16th Oct 2010, 20:31 -
Adding a text logo to a video file without re-saving it to another file?
By coxanhvn in forum EditingReplies: 4Last Post: 19th Dec 2008, 16:03 -
looking for good OCR software that will convert text in jpg to regular text
By jimdagys in forum ComputerReplies: 6Last Post: 27th Jun 2008, 11:38 -
Adding text over original text
By stixster in forum EditingReplies: 3Last Post: 17th Jun 2008, 06:14 -
Capturing Software (adding text on the Fly)
By Soreen in forum Capturing and VCRReplies: 1Last Post: 18th Feb 2008, 00:50
