  1. well im pretty familiar with the dvd ripping burning buisness and just got a new probs
    I use -
    -cucusoft avi-dvd conver 6.0pro to make my huge dvd compatible mpeg file, than i use
    -Cucusoft MPEG to DVD Author to make vob files than i
    -burn it using nero ultra6
    -first problem very chopping does 5 frames and pauses, continues like this the whole movie
    -also I got no audio
    anyhelp verymuch appreciated been worken with this for days
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I don't know this from my own experience, but certainly the experience of quite a few forum members here suggests that CucuSoft is utter crap, in a similar league to any Roxio products. Dump that crapware, use something like DivxToDVD or do it the manual way.
    If in doubt, Google it.
  3. wondering how to fix prob? any help plz
    preciate it
    Fix it by using something else.
  5. Originally Posted by sekc1man
    I use -
    You could also get more familiar with using the best tools for the job eg TMPGEnc Plus for encoding to MPEG2 and TMPGEnc DVD Author to make IFO VOB files ect...
    DVDDecrypter to burn.
    ~Luke~
  6. alright I used
    -TMPGEnc Plus 2.5 to convert my avi to mpeg-2
    -than I used TMPGEnc DVD Author 1.6 to create vob and ifo files
    -I burned it using nero ultra 6
    the video is very good quality and the frames are smooth but I have no AUDIO! does anyone have any tmpgenc settings and/or options to have audio, no sound at all, happens to all my movies... hmmm
    does anyone know the problems, has been doin this for a couple weeks THANKYOU!!
    preciate it!
  7. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    We're gonna need some more info, such as the type of audio in the source AVI - I'm guessing either VBR MP3 or AC3. TMPGEnc is synonymous for choking on this.
    I'd suggest using the latest GSpot (2.52 Beta) on both your AVI and on one of the final VOB files, to see what type your source audio was, and then to see if there's any audio at all in the final product. There's also a chance you encoded to ES (Video Only), which would have given you no audio as well.
    As you can see, we're gonna need a shitload more info than you've provided so far
  8. As stated above, TMPGEnc is lousy at encoding audio. In addition to the above, try raising the priority of Directshow Multimedia File Reader to 2 by right clicking on it. You will find it at Options>Environmental Settings>VFAPI Plug-in. Or, convert the audio to wav with Virtualdub (freeware) or Goldwave (shareware) and enter separately into TMPGEnc. Guides for both to the left. Finally, ensure you use interlaced (page 2 of the wizard). Don't know where it is if only using main window.
