I'm using Premiere Pro to edit my movies and have run into a problem. I can encode to .wmv fine (low file size & good quality), but when I try to convert to either .mov or .mpg, the file size is very large and the audio in .mov is terrible. I would like to be able to create .mov clips that resemble the movie trailers. The trailers are very high quality (vid/sound) and they have a relatively low file size. I have been reading about a program called ProCoder Express (Canopus) and have reviewed great feedback from users. Has anyone here used the program and how does it do encoding avi to mov/mpg via Premiere Pro? I believe it has a direct plug-in with PPro (timeline).
The difference in file size is a product of the container that you use. mpeg likely has the largest file size. For small file size and good quality stick with avi. mpg wouldn't be necessary unless you plan on authoring dvd's. other formats, wmv, mov, rm, can be used, but are not the preferred containers (except for web use) and are harder to work with and have fewer good tools to use.
avi and mpg are the top choices with the most support.Google is your Friend -
Krispy Kritter-
I should have clarified these videos will be used for web use only, so I will need to use the best quality/smallest sizes. I believe mpeg-1 is the correct version to use for the web. The great thing about mpeg video is that any browser should pick it up as apposed to wmv and mov.
Have you experienced ProCoder Express software?
Thanks!
.MOV conversion to .AVI and .MOV HD quality query
By Peewitisland in forum Newbie / General discussionsReplies: 3Last Post: 31st May 2011, 11:22 -
xvid to mov program?
By whoisquilty in forum MacReplies: 0Last Post: 30th Jul 2010, 12:35 -
Program to split .mov files without re-encoding
By Guest in forum EditingReplies: 5Last Post: 21st Jul 2010, 20:09 -
mencoder wont convert the complete file, mov to avi|mov
By bjornieB in forum Video ConversionReplies: 2Last Post: 19th Nov 2009, 07:42 -
DV AVI to DV MOV - without re-encoding?
By arminio in forum Video ConversionReplies: 2Last Post: 4th Mar 2008, 04:42
