I am thinking of getting the 444 or 434. I have read all of the reviews and as a last step would like to pick the brains of some of you. I am very new at this but have some questions. Does anyone know if the 444 will freeze or stop at really low bit levels when doing XSVCD's? I am really interested in this as a format and just want to ensure that it works. Next is there anything that I should be aware of when deciding between these two. I am sure that there is enough of you out there that have these models and know them inside out. Any problems complaints? Anything is helpful. I would like to learn as much as possible to make the best choice.
Thanks for your help....
both great players, you can get the 434 at sears for $134, another good one is the dv-c503 or 603 carosels, you can pick one of these up for around $150-$175 and you don't have to get up to change disks.
I got the 444 and I have no complaints. It will play XVCD with a bit rate of 2200 with no problems (and probably a bit more!).
I don't now what you are looking to use SVCD's for but if it is for VHS copies, forget it as a XVCD actually produces a better picture.
Opinions wanted
By Nelson37 in forum Off topicReplies: 14Last Post: 31st Dec 2009, 23:29 -
pc to tv hook up need opinions
By xsfcloud in forum ComputerReplies: 6Last Post: 4th Aug 2009, 13:51 -
YUV 444 Conversion
By Dave1024 in forum ProgrammingReplies: 1Last Post: 24th Jun 2008, 08:31 -
Opinions Please
By OzarkBaby in forum Newbie / General discussionsReplies: 5Last Post: 17th Dec 2007, 16:11 -
Opinions please - the best codec for.....???
By Lovepeaceguru in forum Video ConversionReplies: 1Last Post: 27th Nov 2007, 15:32
