Alot of new dvd's will not play on my pc.I have a sony dru-510a dvd player/burner.Older dvds play but most new don't even show up in drive,i get a insert dvd into drive error.Anyone know why or how to fix this?
thanks
Are they copy protected DVD's?Originally Posted by gorefiend~Luke~
possibly copy protected,but shouldn't they still play,i just wouldn't be able to burn them.
I had that prob with my sony dvd writer .... remove the drive from ur pc and then remove the cover from the drive and clean the lens (carefully) with a dry cotton bud or cotton wool ball ... replace and try again ... worked for me ..... i found that i had to clean the lens on my sony about once every 5 or 6 months
Yes,I suppose your right on that oneOriginally Posted by gorefiend
~Luke~
No sound when playing playing burned DVD on stand alone player
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2010, 14:11 -
DVD Player crashes when playing dvd with vietnamese subtitle
By ssalim in forum SubtitleReplies: 0Last Post: 28th Apr 2010, 16:52 -
Playing region free DVD on Sony SR200P DVD Player
By merik in forum DVD & Blu-ray PlayersReplies: 5Last Post: 25th Nov 2009, 16:35 -
Playing DVD burned slide show on DVD player problem
By zenfoos in forum Newbie / General discussionsReplies: 4Last Post: 29th Aug 2007, 22:37 -
WinAVI Video Converter 8.1 (DVD gets stuck while playing on home DVD)
By Zuzuu in forum Newbie / General discussionsReplies: 2Last Post: 19th Jul 2007, 13:37
