I have an ATI AIW 900Pro that I use for capture and it does a fine job.
In fact, there's nothing wrong with it at all.
But it doesn't support ATI's component video adapter, which means that if I wanna watch my video files or play games on my HD television, I'm stuck using S-Video![]()
the capture card was a (not exactly cheap!) gift from my girlfriend, and as I said, there's nothing wrong with it -- if I but a replacement (AIW X800XT) she will be PISSED.
so my question is: Can I install another video card (it would have to be a PCI card) that does support component out (720p at least) in my PC?
Yes, I want to have 2 video cards if possible.
One to capture with, and one to use for a 2ndary display.
I have completed my PC specs, just hovering over the button should pop them up.
TIA!
"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!" -
I'm not sure, but I think the only way to have 2 video cards is with the new SLI technology...if that's what you're talking about. You would need a motherboard that supports it, and 2 cards that work with it. Go to Nvidia's homepage for more info. Other than that, I have no idea.
Smile
Smile -
Beavereater is correct. You need the new SLI technology, which is quite expensive at the moment.
hhmmmm....
i quite clearly remember going to CompUSA at least 2 years ago and seeing a PC that was set up with 3 monitors for a flight sim game.
did they do that with just one card?"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
I don't know if you will find component out, but a PCI ATI card with DVI out can probably be used with a ATI DVI to component adapter. Check ATI for the adapter specs to see which cards it works with. I use the ATI component adapter with a AGP card to my Video projector with no problems. Should work the same with a compatible PCI card. There is also a VGA to component adapter, though I don't know much about it.
One of the Matrox Parhelias would be able to drive something like that. My plain old AGP video cards can run two displays at least, the newest two of them support component out. There are cheaper options for a video card with component out than the top-of-the-line ATi card to replace your current one. In fact you can get a pretty good PCI tuner/capture card in addition to it for not much more.Originally Posted by Xylob the DestroyerFB-DIMM are the real cause of global warming
well....
doody!"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
New "editing box", need advice on best use of multiple video cards.
By jaybird in forum Newbie / General discussionsReplies: 0Last Post: 10th Apr 2011, 22:16 -
How can I use multiple usb video capture cards on one computer?
By gbenson in forum Capturing and VCRReplies: 0Last Post: 27th Jan 2011, 20:47 -
What video cards support S-Video & Composite output over VGA via adapters?
By Bix in forum ComputerReplies: 5Last Post: 22nd May 2010, 22:57 -
Video cards with Composite video out and Mandriva
By neftv in forum LinuxReplies: 3Last Post: 24th Jan 2010, 04:25 -
Capture from multiple encoder cards symultanously
By dkearns in forum Capturing and VCRReplies: 0Last Post: 16th Jan 2009, 06:41
