Hi
I have some bin/cue files (vid. tutorials) that I only want to watch on my Mac. I don't care what format they end up in as long as I can have them in the smallest possible size and ... be viewable.
Is there anyway I can play these as they are or do they need to be converted? The bin is 720 MB.
Even if I can end up burning the end result as a .dmg which when mounted, contains a playable file using either QT or VLC. I have Toast, MPeg2Works, ffmpeg (can't remember what version) and 1 or 2 other apps which may be necessary.
Help much appreciated.![]()
Results 1 to 10 of 10
I thought I would be able to play the files as they were but VLC keeps saying "vcd: no movie tracks found". This is happening on three different files. I have VLC v.0.8.2 (I'm running Tiger). Does VLC have a problem with VCD's? Is there something else I can try?
I have a few vid tutorials that I would like to burn to one DVD - keep them all together - which was why I was wondering about converting them - if that is necessary.
Thanks very much. -
Originally Posted by imacaroon
Awesome!
Used Toast, mounted the image and now have my Tutorias inside - in .mov but .. no .DAT (that I can find).
Will this 722 MB burn to a CD? The files inside only come to 628 MB - is the extra 98 MB from Toast? Is it going to be too large and if so, how can I burn it? I don't mind skipping the idea I had about putting them on a DVD - just being able to play them now is great!
Thanks very much!
Ripping DVD's to play on mac
By collink in forum MacReplies: 24Last Post: 4th Nov 2010, 07:26 -
Formate/specs for video file which play smoothly Across G4 MAC/ PC /MAC PRO
By krijes in forum EditingReplies: 1Last Post: 2nd Apr 2010, 05:18 -
How to play CUE in Media PLayer Classic
By lovyagin in forum AudioReplies: 7Last Post: 21st Nov 2009, 00:41 -
Best way to convert/burn/play .mkv H.264 Blu-ray/HD DVD files on a Mac
By iMacMan in forum MacReplies: 7Last Post: 21st Mar 2009, 16:50 -
How do I play/convert .MP4 files to play on my laptop
By tfoster in forum Newbie / General discussionsReplies: 1Last Post: 25th Jul 2008, 20:23
