Used the above to rip a movie (nothing copyrighted), and I got the whole movie no problem, but it left out the menu - just started with the movie. Any ideas why?
Also, the resulting divx file plays in a players supporting Divx except for the actua Divx play - in which case I get an error.
AutoGK only does a particular title from the DVD - not the whole DVD itself, or any menus or anything like that. In fact, AFAIK the only way to put a menu inside DivX is to use the DivX converter and use DivX 6 - a forum search or a look through the Latest News forum for DivX 6 will certainly find more info on this.
If in doubt, Google it. -
Hmm, I have the DivX converter, but you can't use that with a DVD, can you?Originally Posted by jimmalenko
One more question while you're here
Can I have @ ver. of the divX codec on the same machine - 6 and 4.1.2 for example?
And, any idea why my divx player won't play the file but other players that support divx will?
Thanks!! -
I don't know - forum search or a look through the Latest News forum for DivX 6 will certainly find more info on thisOriginally Posted by loopyloops
EDIT:
FOund a topic here that might help. There was also a couple of topics on this the other night - you might need to look through the Newbie/General or DVD to (S)VCD/AVI forums over the last few days to find them.
Sure ... provided that the newer version doesn't try to uninstall the later version when you install it, and also you may have some fun configuring the codecs to play the right material - ie. you may want to use DivX4 to decode Divx 3/4 material, but DivX6 to decode DivX5/6 material.Originally Posted by loopyloops
Don't know. But according to DivX.com, "The DivX Player™ is capable of playing every DivX file ever created, with integrated support for advanced DivX® Media Format features and special enhancements for high definition (HD) playback, providing the ideal way to enjoy all your DivX videos."Originally Posted by loopyloopsIf in doubt, Google it. -
The Divx site says if you have a dvd to .avi pluin, you can use it to convert DVDs or video ts files. I'm pretty sure I have this plugin as it's supposed to come with what I have, but I get an error saying it doesn't support the file type. Hmm.
Audio out of sync 5 seconds - DVD ripped with DVD Decrypter + AutoGK :(
By dtel in forum DVD RippingReplies: 20Last Post: 25th Apr 2010, 03:01 -
DVD Decrypter, AutoGK and Subtitle Times
By sambat in forum Video ConversionReplies: 5Last Post: 13th Feb 2010, 06:55 -
AutoGK - ripping the DVD gets out audio out of sync - okay after DVDShrink
By lchiu7 in forum DVD RippingReplies: 7Last Post: 7th Dec 2009, 23:06 -
Frustrated and Lost ! All I need is a simple menu for VOB files
By vulcan_man in forum Authoring (DVD)Replies: 7Last Post: 26th Feb 2008, 05:12 -
Subtitles problems w/ DVD Decrypter and AutoGK
By coyotewrw in forum DVD RippingReplies: 2Last Post: 4th Aug 2007, 14:15
