Does anybody know what the average time? Ex: months, days or whatever a dvd writer usually lasts before errors occur?
It seems that in the dvd writer section a lot of people say that their dvd writer has stopped working properly.
Yuman
I think its usually down to luck.Make sure you keep your receipt and garuantee.
~Luke~ -
Check the manufacturer's website for the MTBF figure - the Mean Time Between Failures.
Don't forget you always hear about the unlucky ones - my father is using one of my old DVD writers - an A04, that's about 3 years old now and was subjected to very heavy use when I had it. I've never had a burner die on me. I've had a few get replaced when a better model came out, but never one pack up. -
Almost the same here. Besides having 2 dead NEC 2500s, all of my DVD Burners have lasted over the years.Originally Posted by garryheather
Even my pioneer A03 (2001) is still burning a few a day right now. I've never used my burners for anything other than burning DVDs. They've never seen any other type of media. The A03 gets a 20 minute cool down after a burn, my other burners all get 10-15 minute cool down periods.
I had 2 NEC 2500s just up and die. No longer detected by the motherboard, make that any motherboard. Swapped them out with 2 NEC 3500s.
In my closet, or PCs, there are 1 Pioneer A03, 4 Panasonic LF-D321, 2 Toshiba SD-R5112, 4 Pioneer A05, 2 NEC 2500, 2 NEC 3500, 1 Samsung/Toshiba TS-H552U
Which needs to be replaced, it has god awfull burn quality on every speed higher than 4x. I'll retire the A03 and place the samsung there. The Toshiba's have been retired due poor burn quality on 8x Taiyo Yudens, my Panasonics are used daily for DVD-RAM duties.
The average Mean Time Before Failure is 80,000 - 100,000 hours. Roughly 4167 days, or 11.4 years. Use common sense, don't abuse your stuff, and it should last a while.
Change length of an AVI. Reduce/Increase Frame Length
By Buzwinkle in forum Authoring (DVD)Replies: 4Last Post: 10th Aug 2011, 09:08 -
How to burn a dvd that an average computer user cant copy!!
By Imran87 in forum Newbie / General discussionsReplies: 35Last Post: 8th Jul 2010, 15:06 -
What is the average time of ripping a dvd file to an AVI, or WMV
By ManhoefDream in forum Newbie / General discussionsReplies: 2Last Post: 4th Aug 2008, 15:49 -
XP does not recognize my DVD writers as DVD writers thinks they're CD write
By steve1040 in forum DVD & Blu-ray WritersReplies: 5Last Post: 25th Jul 2008, 02:52 -
VBR (2 pass, average bitrate) Encoding for DVD-9
By jcm0320 in forum Video ConversionReplies: 3Last Post: 15th Aug 2007, 10:44
