    Aug 2004
    Israel
    Hello,
    I have an Xvid movie and .srt subtitles for that movie. I would like to know how can I convert the Xvid movie to DivX and at the same time add the subtitle to that DivX movie?
    Thanks in advance!!
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Adding subtitles is covered in the HOW TO section: https://www.videohelp.com/edit#5;20
    Xvid and DivX are both avi formats...no real reason to change them.
    Google is your Friend
    Dec 2004
    Australia
    XviD is not an avi format. It is just a video codec which although can be used in avi can also be used in numerous other containers.
    Should be able to use fuse to mux to a DivX file with subs.
