As source I have an MPG file mixed progressive and telecined with standard pattern PPPII.
Actually I studied how to inverse-telecine the file using mencoder, however even if I'm able to correctly do it (using -vf pullup,softskip), the output quality, using the following command, is bad:
I get some square artifacts each 5 secs.
COMMAND:
/Users/video/Desktop/lastbinary200505/mencoder file_original.mpg -oac lavc -ovc lavc -of mpeg -mpegopts format=dvd -vf scale=720:480,pullup,softskip -srate 48000 -af lavcresample=48000 -lavcopts vcodec=mpeg2video:vrc_buf_size=1835:vrc_maxrate=98 00:vbitrate=5000:keyint=18:acodec=ac3:abitrate=192 :aspect=16/9 -ofps 24000/1001 -o file_destination.mpg
REF:
http://www.mplayerhq.hu/DOCS/HTML/en/menc-feat-telecine.html
see: 7.14.3.4. Mixed progressive and telecine
http://www.mplayerhq.hu/DOCS/HTML/en/menc-feat-vcd-dvd.html
Or alternatively I've used the lossless huffyuv codec. This one works great but as there is no QT HUFF codec I can only view it with VLC or I need ffmpeg for a second conversion before usit it into FCP.
COMMAND:
/Users/video/Desktop/lastbinary200505/mencoder file_original.mpg -oac copy -ovc lavc -lavcopts vcodec=huffyuvred=2:format=422P:vstrict=-1 -vf pullup,softskip,hqdn3d=0:0:3,scale=720:480 -sws 9 -ofps 24000/1001 -of mpeg -mpegopts format=dvd -o file_destination.avi
Isn't it possible to improve the first command line so that the result will be the best quality?
Thanks.
How to continue with 2nd pass if you have .stats and .mbtree files?
By ad.vid in forum Blu-ray RippingReplies: 1Last Post: 21st Dec 2010, 13:28 -
Is it possible to force Ripbot to continue after crash/reboot?
By yorkman in forum Authoring (Blu-ray)Replies: 4Last Post: 12th May 2010, 18:37 -
Any reason to continue using my parallel printer cable?
By zzyzzx in forum ComputerReplies: 25Last Post: 19th Jun 2008, 06:51 -
How to choose continue video lighting (non-heat style) ?
By AAC in forum Newbie / General discussionsReplies: 0Last Post: 13th Mar 2008, 16:03 -
MISSING PROGRESS.APP hence the encoding doesnt continue
By drevinko in forum DVD RippingReplies: 1Last Post: 26th Feb 2008, 21:17
