Results 1 to 9 of 9
  1. Hello people, this is my first time i have posted hear and i just like to say this is a great forum.
    Can someone please tell me how i can convert divx files to dvd to i can watch it on my dvd player.
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hi,
    Do a search for divx to dvd here:
    https://www.videohelp.com/convert
    Programs like tmpgenc can make burnable mpg files for you.
    Kevin
    (guides are under the "how to" on the left of the screen )
    USA
    VSO DivxToDVD is a freeware program that you might try. Works well for most conversions.
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Yep, I'd 2nd DivxToDVD for a quick, no-brainer solution. If you want to learn "the process", I'd recommend this guide.
    There's a few more solutions in the Tools section under All in One DVD Converters, or as yoda mentioned, search the guides section, pick a guide, get the tools and see how you go. Personally I despise most all-in-one tools, but YMMV.
    Oh, and you'll go far if you try searching the forums, browsing the Guides section and looking through the Tools section before posting your question(s). I think you would have found your answer without waiting for anyone to get back to you
    If in doubt, Google it.
    May 2004
    I owe a lot to VSO DivXtoDVD and it's free!!! This program is awesome, no problems for me, great quality, and does the job quick and well. I would highly recommend it!
    Oh, and in your case, it does support PAL (since I noticed you are in the UK) and I think can convert to PAL (look under Standard --> Force PAL 25 Fps).
  6. Originally Posted by video_guy
    If i have a 700-800 mb divx film , and if i convert it to dvd,will there be any change of the quality? Will this program allow me to add .srt subtitles correctly to my new dvd format?
  7. Member ricardouk's Avatar
    Mar 2005
    Portugal
    1- convert your divx film to dvd with VSO DivXtoDVD
    2- demux the dvd into audio and video streams with vobedit(search for the guide in the guides section)
    3- convert your srt sub to the sst sub format using subtitle workshop
    4-open muxman and load your video and audio streams also load your sst sub file and author.
    all the tools i refered are freeware
    thanks for all the people who created them.
    I love it when a plan comes together!
  8. Member ricardouk's Avatar
    Mar 2005
    Portugal
    or you can do it with a "one in all" tool like Avi2Dvd
    also freeware
  9. aurora2dvd is another tool you might look at. it includes menu generation and multiple file sources.
    i like to put multiple tv episodes on a single DVD, and I haven't found a single all in one program that does a good job. i usually end up converting the avi to an mpeg2 and then authoring the DVD with the converted files.
