I want to convert a VOB file to Mpeg2.
I have converted VOB to MPEG before with FlaskMPG with good result but now it seems I have changed some settings by mistake since I doesn't get the good results anymore.
I tried to search for info on this site but found nothing.
Could anyone help me with the FlaskMpg and BBMpeg settings?
For example, what values should I have for Profile ID and Level ID?
the vob is probably already a mpeg2. why would you like to convert? what are you going to do ?
Well, yes and no.
The thing is that I want to edit some mpeg's after I have converted them from VOB to Mpeg2. I can't use the VOB file since I don't get any audio.
Questions regarding recording settings and compression settings
By so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 07:45 -
BBMPEG Multiplexer Question
By Krelmaneck in forum Newbie / General discussionsReplies: 16Last Post: 22nd Apr 2011, 23:59 -
bbmpeg xp patch , page not found
By rabbit_hgc in forum EditingReplies: 8Last Post: 15th Jul 2009, 05:45 -
Best Settings
By devdev in forum DVD RippingReplies: 2Last Post: 26th Jan 2009, 09:46 -
HD Settings
By kiwikiwi in forum EditingReplies: 9Last Post: 13th Dec 2008, 15:20
