I recently captured from VHS to disc using a dvd recorder. The audio is 48kHz, 256k AC-3. In virtualdub, it's SILENT. In WinDVD Player, it sounds fine. In DVD Shrink it plays fine. In various authoring packages it plays fine. Any ideas?
AC3 Filter
Oh, wait. It still won't work with VirtualDubMPEG2. You'll need VirtualDubMod and AVISynth. Then open in VirtualDubMod as a DirectShow source. -
You could try the AC3 Decompressor from fcchandler here. You should then be able to play the AC3 audio.
Melde Melda Vessė
Eruanna ar Eruntano Melda Eruntanohini
"May your days be bright and contact with stupid people limited." -
I tried the AC3ACM that Lantern pointed out. It works with VirtualDUBMPEG2 but performance is pretty bad on some files. Just fine on others.
MPEG-2 VOBs trouble in VirtualDub
By shmizan in forum Video ConversionReplies: 4Last Post: 16th Apr 2010, 10:35 -
new Virtualdub MPEG - still a colorspace problem with MPEG-&
By sanlyn in forum EditingReplies: 6Last Post: 10th Aug 2009, 23:18 -
Virtualdub codec MPEG-2 / MPEG-1
By Astrogirl in forum Video ConversionReplies: 19Last Post: 10th Dec 2008, 12:38 -
Divx/Mjpeg to Mpeg-4 with VirtualDub
By nalooti in forum Video ConversionReplies: 2Last Post: 16th Nov 2007, 23:50 -
using virtualdub mpeg-2 for cropping and need advice
By mrgain in forum EditingReplies: 2Last Post: 10th Jun 2007, 11:59
