i have converted the movie files i want and are dvd ready. I have a program to burn it (copytodvd). But i want to know is there any program that will let me burn a menu on it so i can select the video file? i tryed nero but it says it will take 2hrs for it to be made. So is there anyother program that will let me make a dvd menu with the already made dvd files?
Btw the program i use to make the dvd files is winavi converter if that matters.
Hi,
Are you trying to make motion menus?? That would significantly increase the time needed to author the dvd even if it is fully dvd ready.
Tmpgenc Dvd Author can take your dvd compatiple mpg files and let you make customized menus quite easily. It will be a relatively quick authoring time depending on your computer. Again don't do motion menus if you want it to be quick.
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
DVD Menu Maker
By ozab in forum Authoring (DVD)Replies: 1Last Post: 30th Apr 2008, 20:49 -
vista dvd maker
By benny28 in forum Authoring (DVD)Replies: 8Last Post: 16th Apr 2008, 16:15 -
DVD Maker
By dd1313 in forum Capturing and VCRReplies: 0Last Post: 15th Feb 2008, 09:15 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 11:36 -
Vista Movie Maker and DVD Maker problems
By steve7510 in forum Newbie / General discussionsReplies: 5Last Post: 9th Jun 2007, 22:18
