For the lazy:
Product Description:
D-Subtitler is a little software which let you extract subtitles of your DVD and put it in a .srt file (which is compatible with Mplayer, Video Lan and the majority of Divx Player). To use D-Subtitler, you have to rip your DVD in your hard drive (to remove CSS protection). You can rip it in VIDEO_TS folder or in a big .vob file. Open the result of the rip with D-Subtitler, choose the subtitle track to extract and click on the green button. Warning : With some DVD, when you work with D-Subtitle from a VIDEO_TS folder, the subtitles track is not completely extracted. To fix this problem, you must rip the DVD in a single vob file (OSex or YadeX).
Product Requirements:
Mac OS X 10.3 or later -
I tried it the other day, and it worked just fine. The resulting srt file needs a little editing when it's done, no big deal though.
Problems with DivXland's media subtitler
By cevita in forum SubtitleReplies: 1Last Post: 29th Nov 2012, 20:58 -
Subtitler
By levdr in forum MacReplies: 1Last Post: 15th Nov 2011, 12:43 -
how to set lemony subtitler pro 4 script ???
By 24673583 in forum SubtitleReplies: 1Last Post: 16th Apr 2010, 10:34 -
Recommend a good subtitler?
By Djard in forum SubtitleReplies: 6Last Post: 9th Nov 2009, 02:57 -
how to use subtitler workshop?
By petulaA in forum SubtitleReplies: 12Last Post: 1st Mar 2009, 08:56
