I can't remember how to get my specs...the one where you copy something into Notepad and it has all your specs. Can someone tell me how to do it...I think you type something in RUN...but I can't remember![]()
Results 1 to 11 of 11
Smile
Smile -
Hi,
you can always go to start-control panel-system.
Then in the first tab you'll have all your ram and cpu power you can copy and paste.
That's not the one...there's one where you enter something into RUN and you can save it as a txt file...it has everything...I know its simple...I just can't remember. Some companies ask you to send it when you have a problem with hardware...
Smile
Smile -
Hi,
Is that some config command????? I can't remember what it is.
Yeah...I think that's what it is...damn...this is bugging me. I've been googling it forever
Smile
Smile -
Try typing 'msinfo32.exe' into Run.
EDIT: BTW, I found that by using 'Help and Support' on the start menu, then 'Use Tools to view....' , then 'Advanced System Information'. If you go that route you will see a lot more other options to check your system. It gives you a listing of all available tools for the OS. -
Hi,
try microsofts knowledge base. Do a search for config and you might bump into it faster.
Almost there...I'll keep looking.Originally Posted by redwudzSmile
Smile -
Or you can use CPU-Z and ask it to export all your specifications as an HTML file. Covered here:
https://www.videohelp.com/forum/viewtopic.php?t=253587
recommended minimum system specs for lossless editing?
By leslie80 in forum Capturing and VCRReplies: 2Last Post: 2nd Mar 2011, 00:09 -
(?) min system specs to play MTS avchd files thru MPClassic Home Cin 1.3 ?
By jimcornetet in forum Newbie / General discussionsReplies: 1Last Post: 27th Jul 2010, 19:14 -
What should be specs of PC
By cyberlion in forum EditingReplies: 26Last Post: 6th Jul 2010, 07:50 -
Best LCD TV Specs
By SIRCOOKS in forum DVB / IPTVReplies: 5Last Post: 18th Oct 2008, 03:03 -
Help on laptop specs
By Tbag in forum ComputerReplies: 10Last Post: 4th Aug 2008, 08:26
