Hi, I have a query with regards setting Forced Subtitles
I have a film, not sure of original source as it is from dvd-r image, but it has an english subtitle stream (stream #7) that needs to be forced on for foreign language section translations. These currently do not display automatically....
Having traced the procedure through PGCEdit, I find the part where, if no subtitles have been selected, it should set the subtitle stream to 7 with the command
51 20 00 00 C7 00 0E 00
if ( gprm(14) == gprm(0) ) then { (SetSTN) Set Sub-picture stream = 7, on }
and when it gets to this line, it does change SPRM#2 Sub-Pucture stream, to the value to 71, hence, I am guessing is stream #7 + 1 for on, but it still doesn't show.
I have gotten around it just by removing the Prohibit Stream change in the VTS and can manually select subpic #7, but I wondered why I couldnt get it to change any other way.
I forgot. Here's the guide.
https://www.videohelp.com/~r0lZ/pgcedit/third_party/blutach/How_to_use_PgcEdit_new_macro.htm
forced subtitles
By bogey219 in forum SubtitleReplies: 4Last Post: 6th Nov 2011, 22:00 -
forced subtitles question ...
By zero7404 in forum Blu-ray RippingReplies: 0Last Post: 17th Aug 2011, 22:31 -
Forced Subtitles
By sxj1704 in forum Blu-ray RippingReplies: 4Last Post: 29th Jan 2011, 09:17 -
Forced Subtitles Only In First Stream
By sambat in forum SubtitleReplies: 3Last Post: 28th Apr 2009, 23:05 -
The Mummy - How to get the forced subtitles
By Mascot in forum Blu-ray RippingReplies: 19Last Post: 20th Apr 2009, 21:01
