i am having very ureliable results with dvd media i am using, ie datasafe and datawrite various types, for dvd movie and ps2 backups on both of my ps2's.i have used 2 writers nec and sony
can anyone suggest a proven reliable media for the ps2.
mike
I know some ppl knock memorex but I have used both +/- memorex and have no problems playing backed up dvd's in my ps2
Try using another burning app. My ps2 works only when I burn the movie with Nero.
my ps2 works fine with ritek media...I have a sony dru burner and I ALLWAYS burn at 1x, especially for ps2 backups. If you havn't tried yet, try burning at 1x for the ps2 backups.
1x makes no difference.
This is simply an issue of using better media.
Try some AZO-based media, like MCC (Verbatim)Want my help? Ask here! (not via PM!)
Smurf,
I did a lot of reading on the whole speed thing...but basically, I have burned things at 4x that didn't work, and then burned that at 1x (directly after) and they worked fine (ps2 games). coincedence? maybe. I can't explain it and I'm sure their are technical reasons why burning at faster speeds is no worse, but i'm just sharing my personal experience. -
I have good luck with ritek -R GO4's. I use my dvd cloner at max speed and never have any problems. It copies the original directly. I just found out I need a replacement laser lens. Debating on replacing lens, or replacing the entire ps2.
HH -
I modded a PS2 forum for years.
It depends on what chip you have in your PS2 & what version PS2 you have.
Try TY media, write at 2x for starters. If that works you can write faster. Lots of people say Riteks are great in PS2s but they weren't for me. Maxell is also working great for me.
PS2 DVD Region Free Code
By THRobinson in forum Media Center PC / MediaCentersReplies: 0Last Post: 28th Dec 2010, 12:59 -
PS2 and DVD info from region1 moving to region 2. confussed totally here
By joelliott in forum Newbie / General discussionsReplies: 7Last Post: 14th Dec 2010, 16:52 -
How To Convert DVD Media Made From VHS Media For Sharing Online
By BlazingSpeed in forum Video Streaming DownloadingReplies: 0Last Post: 11th Dec 2010, 14:20 -
Playing ripped dvd in ps2
By hrgrosskopf in forum Newbie / General discussionsReplies: 1Last Post: 11th Jan 2008, 09:04 -
Burned DVD plays OK on standalone - not on PS2!?!
By offensekilla in forum Authoring (DVD)Replies: 5Last Post: 31st Jul 2007, 12:07
