I have already asked this ?, but never got a answer to the problem so here go`s again why do it takes ages to make menus using tmpgenc dvd author I have 2 movies which I put to-gether with dvdshrink now I am making menus with tmpgenc dvd author but its now only on 59% and has taken so far 1 Hour 26 mins isnt there a faster way as + using dvdshrink and dvd author its taken ages to do my 2 movies is there another quicker program to do this make menus for movies Im on win xp pro have a 2.200mhz 716mb ram
Closed Thread
It takes me about 20-25 minutes, every time. Motion menus take a little longer. Then again, I do have a P4 3.0 w/ 1GB RAM
I'd suggest that there's something dodgy with either your install or your PC. Maybe your hard drive needs defragmenting ... maybe you should disable all unneeded services / CPU hogs ... depending on how your HDDs are set up, have your source on one HDD and output to the other ... maybe a fresh install of XP will speed everything up ...If in doubt, Google it.
no need to create a new topic. reply to your first topic instead. and remember that we may not be able to solve all problems....
https://www.videohelp.com/forum/viewtopic.php?t=274090&highlight=
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
Does Tmpg Divx Author encode or it only author ?
By BlackShadow90 in forum Authoring (DVD)Replies: 3Last Post: 29th Jul 2008, 04:56 -
Create DVD with TMPGEnc DVD Author 3 and not read on DVD Player
By Salutatous in forum Authoring (DVD)Replies: 1Last Post: 22nd May 2008, 11:22 -
Author 5.1 DVD
By Astrogirl in forum Authoring (DVD)Replies: 4Last Post: 7th Apr 2008, 16:43
