Hello,
It has been a long time since I've tried capturing video off of my camera. I am trying to hook up a Sony DCR-PC110 to my D-Link DFW-500 card under Windows XP MCE. When I turn on the camera, Windows detects it and adds an entry under Imaging Devices in the Device Manager, but the connection breaks and the camera disappears within 1-2 seconds. Because I'm running XP MCE, I can't uninstall SP2. Is there any way for me to capture the data?
I've successfully used the card and camera under regular WinXP.
Thanks.
s u n i l \ o n l i n e
Use a net. :POriginally Posted by sunil\online
I've seen quite a few similar posts where SP2 seems to be the common thread. There's a few possible solutions, there was a recent thread where the OP went into device manager and rolled back the driver which allowed him to manually select the correct driver. His cam wasn't disconnecting but inoperable from the start but recognized.
There's also some patches avaialble from MS regarding FW devices but none that I have seen specific to what you describe. You might want to see what you can find there.
Here's a link I have:
https://www.videohelp.com/forum/viewtopic.php?t=252426
There's also the possibility that something has happened to your cam? Maybe the cable? If you have access to another comp with FW I'd make sure that it's functioning correctly.
One last thing to note, I had a similar issue where the cam would disconnect shortly after connecting to the port on the front of my computer. Connecting it to the rear port posed no problems. the problem was that the front port was connected to my Audigy soundcard instead of directly to the mobo. Connecting it to the mobo fixed the issue. My guess is that there just wasn't enough resources available to run it through the sound card, I think the display card was on the same IRQ as well.
If you have just recentlty installed this card on a new computer try moving it to a different PCI slot.
DVD Flick Disappears
By Perco in forum Newbie / General discussionsReplies: 3Last Post: 22nd Mar 2012, 08:54 -
After Effects: Text Disappears..
By Coldkilla9 in forum Newbie / General discussionsReplies: 1Last Post: 29th Oct 2011, 15:09 -
Desktop background disappears in xp...
By pinetop in forum ComputerReplies: 9Last Post: 19th Jul 2010, 02:05 -
Audio Disappears..
By Hairykiore in forum Video ConversionReplies: 1Last Post: 25th Feb 2010, 19:28 -
Toast Disappears and I am Mystified
By Nacus in forum MacReplies: 8Last Post: 20th Aug 2008, 10:34
