    Jul 2005
    Hi, I am a newbie trying to convert some avi files with subtitles into mpeg2 for svcd burning. I followed instructions on the ffmpegx website. It then starts to starts to encode, but then fails once it reaches 100%. I didn't really play around with the settings. i also got a .mpv file, which was not what the insturctions said should result. The resulting video has not sound and the subtitles only last until the middle. Could any of you help and let me know what I am doing wrong? Here is a screen shot of the logfile. I took out some of the middle part.
    Encoding started on Tue Jul 12 02:32:56 EDT 2005
    /Users/nciyeu/Desktop/VIdeos/SS/SS1.avi.ff/
    /Users/nciyeu/Desktop/VIdeos/SS/SS1.avi.ff/: File exists
    -f 5 -b 2661 -q 6 -B 260 -V 230 -a 2
    INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
    -F 1
    INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
    INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
    MPlayer dev-CVS-050123-19:55-3.3 (C) 2000-2005 MPlayer Team
    Mac OSX static build for ffmpegX
    AltiVec found
    CPU: PowerPC
    CommandLine: '-noframedrop' '-vo' 'yuv4mpeg' '-ao' 'pcm:waveheader' '-v' '-osdlevel' '0' '/Users/nciyeu/Desktop/VIdeos/SS/SS1.avi' '-aid' '2' '-sid' '1'
    get_path('font/font.desc') -> '/Users/nciyeu/.mplayer/font/font.desc'
    font: can't open file: /Users/nciyeu/.mplayer/font/font.desc
    Font /usr/local/share/mplayer/font/font.desc loaded successfully! (206 chars)
    Using Unoptimized OnScreenDisplay
    Using Darwin accurate timing
    Terminal type `unknown' is not defined.
    get_path('input.conf') -> '/Users/nciyeu/.mplayer/input.conf'
    Can't open input config file /Users/nciyeu/.mplayer/input.conf: No such file or directory
    Can't open input config file /usr/local/etc/mplayer/input.conf: No such file or directory
    Falling back on default (hardcoded) input config
    get_path('SS1.avi.conf') -> '/Users/nciyeu/.mplayer/SS1.avi.conf'
    Playing /Users/nciyeu/Desktop/VIdeos/SS/SS1.avi.
    [file] File size is 179388416 bytes
    STREAM: [file] /Users/nciyeu/Desktop/VIdeos/SS/SS1.avi
    STREAM: Description: File
    STREAM: Author: Albeu
    STREAM: Comment: based on the code from ??? (probably Arpi)
    AVI file format detected.
    list_end=0x22D6
    ======= AVI Header =======
    us/frame: 41708 (fps=23.976)
    max bytes/sec: 0
    padding: 0
    MainAVIHeader.dwFlags: (272) HAS_INDEX IS_INTERLEAVED
    frames total: 34269 initial: 0
    streams: 2
    Suggested BufferSize: 0
    Size: 640 x 480
    list_end=0x1138
    ==> Found video stream: 0
    ====== STREAM Header =====
    Type: sdiv FCC: divx (64697678)
    Flags: 0
    Priority: 0 Language: 0
    InitialFrames: 0
    Rate: 2997/125 = 23.976
    Start: 0 Len: 34269
    Suggested BufferSize: 74573
    Quality 10000
    Sample size: 0
    found 'bih', 108 bytes of 40
    ======= VIDEO Format ======
    biSize 40
    biWidth 640
    biHeight 480
    biPlanes 1
    biBitCount 24
    biCompression 1482049860='XVID'
    AVI: invalid audio stream ID: 2 - ignoring (nosound)
    Regenerating keyframe table for MPEG4 video
    list_end=0x21CA
    ==> Found audio stream: 1
    Type: sdua FCC: (0)
    Flags: 0
    InitialFrames: 1
    Rate: 16000/1 = 16000.000
    Start: 0 Len: 22869504
    Suggested BufferSize: 7229
    Quality -1
    Sample size: 1
    found 'wf', 30 bytes of 18
    ======= WAVE Format =======
    Format Tag: 85 (0x55)
    Channels: 2
    Samplerate: 48000
    avg byte/sec: 16000
    Block align: 1
    bits/sample: 0
    cbSize: 12
    mp3.wID=256
    mp3.fdwFlags=0x4000000
    mp3.nBlockSize=32769
    mp3.nFramesPerBlock=256
    mp3.nCodecDelay=0
    list_end=0x22D6
    AVI: dmlh found (size=248) (total_frames=34269)
    list_end=0xAA0825E
    Found movie at 0x280C - 0xAA0825E
    Reading INDEX block, 68528 chunks for 34269 frames (fpos=0x0)
    AVI index offset: 0x2808 (movi=0x280C idx0=0x4 idx1=0x1C4A)
    Auto-selected AVI video ID = 0
    AVI_NI: No audio stream found -> no sound.
    AVI video size=154829062 (34269) audio size=0 (0)
    VIDEO: [XVID] 640x480 24bpp 23.976 fps 866.6 kbps (105.8 kbyte/s)
    [V] filefmt:3 fourcc:0x58564944 size:640x480 fps:23.98 ftime:=0.0417
    get_path('sub/') -> '/Users/nciyeu/.mplayer/sub/'
    get_path('default.sub') -> '/Users/nciyeu/.mplayer/default.sub'
    Using (default) progressive frame mode.============================================= =============================
    Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
    INFO: libavcodec init OK!
    Selected video codec: [ffodivx] vfm:ffmpeg (FFmpeg MPEG-4)
    Audio: no sound
    Freeing 0 unused audio chunks.
    Starting playback...
    [ffmpeg] aspect_ratio: 1.333333
    VDec: vo config request - 640 x 480 (preferred csp: Planar YV12)
    Trying filter chain: vo
    VDec: using Planar YV12 as output csp (no 0)
    Movie-Aspect is 1.33:1 - prescaling to correct movie aspect.
    VO Config (640x480->640x480,flags=0,'MPlayer',0x32315659)
    VO: [yuv4mpeg] 640x480 => 640x480 Planar YV12
    VO: Description: yuv4mpeg output for mjpegtools
    VO: Author: Robert Kesterson <robertk@robertk.com>
    INFO: [yuvscaler] SVCD output format requested in NTSC norm
    INFO: [yuvscaler] input: frame size: 640x480 pixels (460800 bytes)
    INFO: [yuvscaler] input: frame rate: 23975999/1000000 fps (~23.975999)
    INFO: [yuvscaler] input: interlace: none/progressive
    INFO: [yuvscaler] input: sample aspect ratio: ?
    INFO: [yuvscaler] from 640x480, take 640x480+0+0, NOT_INTERLACED/PROGRESSIVE
    INFO: [yuvscaler] scale to 640x360, 640x480 being displayed, NOT_INTERLACED/PROGRESSIVE
    INFO: [yuvscaler] Scaling uses the RESAMPLE algorithm,
    INFO: [yuvscaler] without line switching
    INFO: [yuvscaler] without time forwarding
    INFO: [yuvscaler] Without luminance correction
    INFO: [yuvscaler] Without chrominance correction
    INFO: [yuvscaler] black lines: 60 above and 60 under
    INFO: [yuvscaler] black columns: 0 left and 0 right
    INFO: [yuvscaler] frame rate: 23.976 fps
    INFO: [yuvscaler] Scaling ratio for width is 1 to 1
    INFO: [yuvscaler] and is 4 to 3 for height
    INFO: [yuvscaler] Specific downscaling routing number 7
    INFO: [yuvscaler] output: frame size: 640x480 pixels (460800 bytes)
    INFO: [yuvscaler] output: frame rate: 23975999/1000000 fps (~23.975999)
    INFO: [yuvscaler] output: interlace: none/progressive
    INFO: [yuvscaler] output: sample aspect ratio: ?
    INFO: [mpeg2enc] Selecting SVCD output profile
    ++ WARN: [mpeg2enc] Generating dummy SVCD scan-data offsets to be filled in by "vcdimager"
    *** [vo] Allocating (slices) mp_image_t, 640x480x12bpp YUV planar, 460800 bytes
    G-2 video to /Users/nciyeu/Desktop/VIdeos/SS/SS1.avi.ff.mpv
    INFO: [mpeg2enc] Horizontal size: 640 pel
    INFO: [mpeg2enc] Vertical size: 480 pel
    INFO: [mpeg2enc] Aspect ratio code: 2 = 4:3 display
    INFO: [mpeg2enc] Frame rate code: 1 = 24000.0/1001.0 (NTSC 3:2 pulldown converted FILM)
    INFO: [mpeg2enc] Bitrate: 2661 KBit/s
    INFO: [mpeg2enc] Quality factor: 6 (Quantisation = 6) (1=best, 31=worst)
    INFO: [mpeg2enc] Field order for input: none/progressive
    INFO: [mpeg2enc] New Sequence every 9999 Mbytes
    INFO: [mpeg2enc] Assuming non-video stream of 260 Kbps
    INFO: [mpeg2enc] Search radius: 16
    INFO: [mpeg2enc] GOP SIZE RANGE 9 TO 15
    INFO: [mpeg2enc] Setting colour/gamma parameters to "unspecified"
    INFO: [mpeg2enc] Progressive format frames = 0
    INFO: [mpeg2enc] Using default unmodified quantization matrices
    INFO: [mpeg2enc] Buffering 39 frames
    INFO: [mpeg2enc] SETTING AltiVec for QUANTIZER!
    INFO: [mpeg2enc] SETTING AltiVec for MOTION!
    INFO: [mpeg2enc] SETTING AltiVec for TRANSFORM!
    INFO: [mpeg2enc] SETTING AltiVec for PREDICTION!
    % 0.0% 0 0
    quant=6.00 total act= 21400.5
    3 12% 255% 0.0% 0 0
    V:1000.0 23976/23976 10% 261% 0.0% 0 0
    V:1000.0 23977/23977 10% 261% 0.0% 0 0 (skipped the rest.....)
    (then .....)
    V:1429.3 34269/34269 10% 251% 0.0% 0 0
    ds_fill_buffer: EOF reached (stream: video)
    EOF code: 1
    uninit video: ffmpeg
    Exiting... (End of file)
    INFO: [yuvscaler] End of stream!
    INFO: [yuvscaler] Normal exit: end of stream with frame number 34270!
    INFO: [mpeg2enc] Guesstimated final muxed size = 410923175
    wait, encoding to mp2 audio with mp2enc...
    /Applications/ffmpegX.app//Contents/Resources/mencvcdX: line 213: /Users/nciyeu/Desktop/VIdeos/SS/SS1.avi.ff//audiodump.wav: No such file or directory
    INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
    INFO: [mplex] File /Users/nciyeu/Desktop/VIdeos/SS/SS1.avi.ff.mpv looks like an MPEG Video stream.
    **ERROR: [mplex] Unable to open file /Users/nciyeu/Desktop/VIdeos/SS/SS1.avi.ff.mpa for reading
  2. The video size of 640x480 that you used is wrong. NTSC SVCD is always 480x480. Try again and if you get again the same error, keep the .mpv file, then convert your AVI to audio only by using the 'movie audio to mp2' preset, finally combine the mpv and mp2 files by using the "Mux as.. SVCD" tool.
    Jul 2005
    Thanks for the heads up. i did what you said and i produced ,mpg file. I use roxio toast 6 for burning, and it wouldn't allow me to burn the file because it wad bigger than the disc. i also couldn't use the edit function to specify a time sequence. Is there an easy way to split the file at this point, or should I split the video and audio files in the beginning and then mux them separately? Thanks for the help
  4. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    How big is the mpeg file? Did you use the Super Video CD setting in Toast?
    Jul 2005
    It is around 2.7 GB. I did use the SVCD setting. I tried using the VCD setting, but it also didn't alow me to choose the trim the movie.
    To recap the steps I did before:
    1. avi and srt file encoded to mpeg (it did not encode properly), giving me only mpv
    2. avi audio encoded into mp2 separately
    3. muxed both files as svcd
    4. Cannot burn the resulting mpg file because it is too big
