I need help with figuring out the start frames and end frames. I have a 153 minute movie and need to burn it to two 800mb cd-rs in vcd format. how do I figure out what will be my start and ending frames. I know I have to do this a second time to create two vcds for the complete movie that I want to burn. I've seen a formula here but I can't find it again help
Well, i'm not familiar with any formula, but look at it this way, where you have the frames at the top, you also have the time, so when you move the location bar, the frames and time are both being updated.
VCD Standard = 10mb for 1min, therefor, your movie is 154min, if you split it by half it would be 77min per movie, perfect for 2 80min CD's, you even got 3min to play around with, now, when you scrool to that 77min location, I suggest you look for what i call a transition scene, usually a scene where teh Audio is at 0 and the scene changes in one frame, so you end the first part with one frame and start the other part with the next frame.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
mencoder: seeking to frames (or cropping start frames)
By manchurian_candidate in forum LinuxReplies: 3Last Post: 13th Dec 2010, 09:53 -
Silent frames and/or wrong clip start with Movie Maker
By fvisagie in forum EditingReplies: 0Last Post: 18th Aug 2009, 08:55 -
Inserting blank frames with logos before movie start
By multiplex in forum Newbie / General discussionsReplies: 9Last Post: 1st Oct 2008, 21:30 -
Tenders V-Dub MP3 Freeze VBR Audio and Bad Frames Guide
By tenders in forum User guidesReplies: 79Last Post: 15th Sep 2008, 22:34 -
Sefy's Guide and Correct Setting for DVD (NTSC).mcf
By moviebuff2 in forum Newbie / General discussionsReplies: 8Last Post: 1st Aug 2007, 10:01
