I used a standard 15 cable and when I push the TV/AV button to the proper setting, the Microsoft windows logo appears,but the strat up menu does not and the screen goes blank. What am I doing wrong?
Is there a way to get internet access while being in safe mode?On lowering the resolution, I went to the control panel, clicked on the display icon, clicked on settings and made sure the screen resolution was on the lowest point(800 by 600 pixels). I do not know what I am doing wrong?
Was the LCD working in safe mode or are you using a second monitor?
If it worked in Safe mode, then did not when rebooting after setting to 800x600, then try changing the refresh rate to one specified in the LCD manual.
Safe mode will be 640x480. That may be the max the LCD will handle.
RTFM. -
Just checked the specs on that monitor. Max resolution is indeed 640 x 480. Many cards don't go that low anymore. You might try using an S-video out card, but frankly it just is not good enough to serve as a PC monitor.
LCD Monitor Problem
By Soopafresh in forum ComputerReplies: 8Last Post: 27th Apr 2008, 04:11 -
Weird Toshiba HD-A2 problem on a standard PC LCD monitor
By danimal99 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 9th Nov 2007, 13:07 -
Polaroid branded LCD TVs with tuners- anybody have comments?
By ahhaa in forum DVB / IPTVReplies: 7Last Post: 1st Nov 2007, 15:45 -
Displaying Photos on an LCD Monitor or LCD TV
By jbsiegel in forum DVB / IPTVReplies: 3Last Post: 25th Sep 2007, 13:29 -
LCD Monitor...is it a problem?
By ron spencer in forum ComputerReplies: 6Last Post: 24th Sep 2007, 08:24
