I just bought LOTR Extended edition. I want to create a single disk backup.
I will use DVDecrypter to rip it. Then I will use VobBlanker to remove the extras and shrink it down a bit. Then I will use DVDShrink on it. now this all seems good so far, here come the problem.
The procedure I have listed above will be performed on each disk separately. I want to know if I can join the to disk together and if I can create one very large menu that will hold both menu sets. I plan on using a 8.4GB disk. I have also thought that DVDlab pro may help?
Looking for some help in accomplishing this task guides are great.
You can join 2 DVD's together using DVDremake PRO.
I suggest taking a look at the website to see if it will do what you want regarding the menu.
dvdremake pro will do that but i think you will have to pay attention to the layerbreak when recording the final product, theres a guide here on how to do it with pgceditOriginally Posted by oberon_black
https://www.videohelp.com/~r0lZ/pgcedit/third_party/blutach/dl_burning_with_pgcedit.htmI love it when a plan comes together! -
Kinda depends on wot you actually want to back up..
I am no videophile, but i would;
1) Use DVD Decrypter to make a full ISO image of each disc
2) Then use DVD Shrink to Re-Author, opening each ISO in turn and picking the bits i want to keep.
3) I would then keep this disc to use and the original as the backup.
Hope that makes sense
PS. my method only uses free software! :P -
This the order I'd do it in ....
1. Rip with DVDDecrypter
2. Remove unwanted material in VOBBlanker
3. Merge using DVDRemake Pro
4. Shrink & burn with DVDShrink
Although I've got a funny feeling that you can actually use VOBBlanker to do the ripping while you're removing unwanted material, so step 1 might be obselete
The benefit of DVDRemake Pro here is that it will just create a simple top-level menu that links to each of the discs' main menus, and it's as simple as loading disc 1, loading disc 2, then going to Tools > Merge - guide here. It truly could not be simpler. If you want to play around a bit, you can also add your own top-level menu in - guide here.If in doubt, Google it.
Error backing up brand new disc
By pugvader in forum Newbie / General discussionsReplies: 3Last Post: 25th Jan 2009, 19:25 -
Empty DVD Disc with a movie on it ???
By macbuz in forum MacReplies: 8Last Post: 8th Jan 2009, 13:42 -
Backing-up Vhs movie tapes to Dvd
By Gerald Sr. in forum Newbie / General discussionsReplies: 4Last Post: 1st Oct 2008, 00:23 -
Order in which to process the backing up of a movie
By Hurre in forum Authoring (DVD)Replies: 11Last Post: 7th Apr 2008, 10:09 -
Arghhhhh backing up a KARAOKE CD+G disc
By the-doctor in forum Newbie / General discussionsReplies: 3Last Post: 24th Mar 2008, 23:06
