Have a Zenith progressive scan dvd that says plays dvdr's and rw's. burned a disc but won't recognize it in the player. Can someone please help?
Results 1 to 10 of 10
What format is the DVD player supposed to play +R/RW or -R/RW ?
Are you using the correct format of recordable disc in the player ?
So is your DVD player capable of playing + format discs ?
Take a look at the DVD player section to the left of this screen and see if your player is listed, you can then see if it is capable of playing + format discs.
https://www.videohelp.com/dvdplayers.php?DVDname=zenith&Search=Search&chipset=&country=...y=Name&hits=25
As you will see there are a lot of zenith players that are unable to play recordable discs !
If you can't find a listing for it then I would suggest trying to see if you can borrow a -RW from someone to test in your player.
Also, what message is you player giving you with the disc inserted and what software are you using to create your recorded DVD's.
The software you are using can play a part in making the discs readable or not !
the progressive scan is a zennith zda 311, plays dvd+-r. error message says no disc error or can't read. I burned the disc through benq software or Nero
OK, I think there is a very simple answer to your problem, if you take a look on this page and find your DVD player model at the bottom of the page you will see that the DVD+-RW options are greyed out which says to me that your DVD player is not capable of playing DVD/RW's,
https://www.videohelp.com/dvdplayers.php?DVDname=zenith&Search=Search&chipset=&country=...erby=Name#next
However, if you are adamant that your player can play RW discs then let us know what process you are using to burn your discs. Give as much detail as you can so we can see whether the problem lies in the way you create your DVD's.
Have you tried burning a write once disc such as a DVD-R or DVD+R with your burning process ?
I would recommend trying this first to see if your player will recognise the disc, this will give you an indication as to whether your problem is with the burning process or with the discs.
problem is that I went to the panel and saw that it takes dvd+-r, vcd and cdr's. I put in the dvd +r and it still says check disk, then ejects it. What do I need to do to have it play a burnt disk using nero.
I suggest that you...Originally Posted by valby1
Originally Posted by HARRYSPADGE"Art is making something out of nothing and selling it." - Frank Zappa -
For a start I would forget NERO for burning and give DVDdecrypter a try for your burning needs, you may then start to get some success.Originally Posted by valby1
I suggest that if you want to sort this problem out that you start to read properly the replies you are getting and take action on that advice.
You keep asking how to make your discs work but you dont seem to be willing to give up any information on how your doing them.
Help us to help you !!
CD-R read error, blank disc
By avextraxjp in forum DVD & Blu-ray WritersReplies: 1Last Post: 25th Jan 2012, 23:58 -
Womble mpeg video editor I get "No disc or disc error"
By pumpkinslion in forum Newbie / General discussionsReplies: 2Last Post: 3rd Nov 2010, 20:32 -
DVDDecrypter error reading disc
By walker08 in forum DVD RippingReplies: 11Last Post: 7th Apr 2009, 00:54 -
Illegal Disc error
By smackypete in forum Authoring (DVD)Replies: 10Last Post: 19th Jun 2008, 20:00 -
Illegal Disc Error
By ScottM808 in forum DVD & Blu-ray WritersReplies: 25Last Post: 12th Jul 2007, 15:51
