Has anyone yet to try capturing google earth into an avi? Seems like it would be a cool thing to play around with. I tried it with camtasia studio, but didn't have any luck.
Look in the settings for Google Earth and you'll see there's various DirectX and OpenGL modes.
Experiment again with Camtasia Studio with the various different graphics modes.
I think Google Earth defaults to software emulation for DirectX/OpenGL when first installed, regardless of what video card you have installed in your pc, leaving any (available) hardware acceleration available unused.
I'd guess that it's running in software emulation mode and Camtasia 'may' work if you enable hardware acceleration.
Sorry i can't be more specific about the settings but i uninstalled Google Earth from my PC once i got fed up with it!
Martin. -
Well, I got camtasia to work if I unchecked the 'disable display accelleration' checkbox...it shows this popup when I do that...
Problem with doing that is it records very choppy and pretty much useless avi's. If i leave the 'disable display acceleration' checked the avi's are typically much better, but google earth just goes black and it doesn't record it. I tried both directx and opengl settings in Googlearth.
I'l try and mess with camtasia settings a tad more. -
Would this work???
http://www.fraps.com/"The name on the front of your shirt is more important than the name on the back"
Kurt Russell - Miracle -
Thats Tmax,
that is exactly what I was looking for. Guess camtesia can't capture dirextx renderings, but this thing did exactly the trick. It does kind of beat up on your framerate, but it's a cool app. -
Glad I could help!
Latest version of Google Earth?
By alegator in forum ComputerReplies: 2Last Post: 15th Feb 2010, 19:38 -
Google Earth on Mac
By Prot in forum MacReplies: 0Last Post: 14th Jun 2009, 21:02 -
Movie Making with Google Earth (GE)?
By solarblast in forum EditingReplies: 8Last Post: 7th Jan 2008, 12:20 -
Fun with Google Earth
By Supreme2k in forum Off topicReplies: 1Last Post: 28th Sep 2007, 12:44 -
What is the best way to screen capture from google earth?
By sneaux in forum Newbie / General discussionsReplies: 3Last Post: 13th Jun 2007, 16:57
