I've got an MPEG-1 file that GSpot says is 352x240 with Frame Aspect Ratio (FAR) of 1.467 (22:15), Pixel Aspect Ratio (PAR) of 10:11 and Display Aspect Ratio (DAR) of 1.333(4:3). When I play it in WMP, Media Player Classic and VLC Player it is full screen (practically anyway - tiny bars at the top and bottom).
I'm using Virtualdub to convert it to xvid so the file size will be smaller so I can fit the whole season on DVD to be played on an MPEG-4 capable DVD player. However, the converted xvid has larger bars at the top and bottom when I play it in WMP or Media Player Classic - not VLC player though.
GSpot says that the avi is 352x240 with Frame Aspect Ratio (FAR) of 1.467 (22:15), Pixel Aspect Ratio (PAR) of 1.000 and Display Aspect Ratio (DAR) of 1.467(22:15).
From that I assumed the problem was the Pixel Aspect Ratio so in Virtualdub I went into the xvid configuration, clicked 'more' next to Profile @ Level (AS @ L5), went to the Aspect Ratio tab and changed the pixel aspect ratio from square (1:1) to 4:3 NTSC (10:11). That didn't change anything. I tried setting the Picture Aspect Ratio to 4:3 and that also didn't change anything. I'm using Full Processing Mode, Virtualdub 1.6.9 and xvid 1.0.3. Does anyone have the answer?
Unless you are using the latest beta of of Xvid the aspect ratio is ingored on playback. Everything is assumed to be 1:1 pixel aspect ratio. Either switch to the Xvid beta or use a 320x240 frame size.
Using VirtualDub to Fix Aspect Ratio
By Djard in forum EditingReplies: 15Last Post: 10th Sep 2013, 17:33 -
Pixel Aspect Ratio in virtualdub
By wabsnazm in forum Newbie / General discussionsReplies: 6Last Post: 10th May 2011, 15:57 -
VirtualDub aspect ratio
By MarioB in forum EditingReplies: 3Last Post: 1st Dec 2009, 18:16 -
Xvid Playback Aspect Ratio Problem
By midders in forum Video ConversionReplies: 3Last Post: 1st Apr 2009, 14:24 -
Aspect ratio problem using virtualdubmod or virtualdub
By anindyanuri in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2007, 08:31
