K, i have a question about this DVD player:
https://www.videohelp.com/dvdplayers.php?DVDname=SD-2805&Search=Search&chipset=&country...y=Name&hits=25
I've never tried to make a CD-MP3, so these may seem like really dumb questions
When it says it can play MP3s, does it mean on a CD and/or DVD?
How can I tell if it can play DVD-audio?
Is there any advantage DVD-audio has over DVD-mp3 if I only plan on playing the music on this specific player?
1.Most DVD players only support CD-MP3,try a CD-RW and DVD/RW.
2.Few players support DVD-AUDIO or SACD.
3.DVD-AUDIO uses 2ch or 5.1ch LPCM audio(uncompressed/24bit/48-192kHz) and sounds better than MP3.The problem with DVD-AUDIO is you can't rip them and the selection of titles sucks.
I have a Toshiba SD-4900 and it plays everything,unfortunatly they don't make it anymore...you might try the SD-4960. -
I didnt realize I had some CD-RWs...I'll try those out. I only want music to play for a party that I'm having, and then I'll be done with the discs...but if MP3 cant play in 5.1, i dunno then....
edit: oops, read wrong, 5.1 is supported for MP3....seems that the CD-MP3 worked, I think I'll just use that, as everyone will be drunk anyway, and I dont think anyone would know/care for the difference -
Almost all music is recorded in stereo anyway...so 5.1 is useless.
Google is your Friend
question on speakers with MP3 playing capabilities
By ktnwin in forum Portable VideoReplies: 3Last Post: 10th May 2013, 23:16 -
question. FAAC or MP3 lame for videos
By llmercll in forum Video ConversionReplies: 4Last Post: 1st Feb 2009, 23:05 -
Question about using Audacity to join mp3 files
By jimdagys in forum AudioReplies: 2Last Post: 25th Dec 2008, 08:21 -
MP3 Player question
By Franza in forum Off topicReplies: 3Last Post: 15th Nov 2007, 18:47 -
mp3 conversion question
By tecstar in forum AudioReplies: 7Last Post: 10th Jun 2007, 22:19
