Ok when you choose Frame Accurate Editing instead of Video Mode Editing when you do HDD---->DVD, it saids that you cannot do a high speed copy. So does that mean the quality will not be the same if it does the recording in real time? I don't care about doing it in real time, I'm just worried that it won't be the quality of the original.
I have the Pioneer 510H and, according to the manual, the editing is similar to the 531H. However, my experience may be different than yours.
I typically do frame accurate editing in the Navigator window rather than in a playlist. This is more risky because once you delete something it's not still available like it is with a playlist edit. However, I can still do high-speed copying along with my frame accurate edits.
A drawback is that where the edits appear there will be a brief freeze (or pause) of the video when played back from the burned DVD-R. It's similar to what you see on a commercial DL DVD where the layer break occurs.
When I edit in the playlist I don't use frame accurate editing. The frames I lose (or gain) are typically around commercial breaks and they are no big deal to me.
If I did choose to do frame-accurate editing in the playlist then I'd also choose to encode the video to the HDD at a high quality setting and then use real-time recording to DVD at whatever the appropriate setting should be. This way it is unlikely I could notice any quality loss (it might be there but I won't see it). -
Re-encoding probably actually only occurs at the edit point. That's how it works for software frame accurate MPEG2 editors like MPEG-VCR and MPEG Video Wizard. There is no loss of quality since the rest of the file is not re-encoded (unless it is also being compressed to fit).
Which Wal-mart did you buy the 531? I have gone to like 4 srtores here in california and they don't have it any. Is it only for select states? let me know
Shawn
Testing H264/AVC frame accurate editing (AVCHD/MOV/MP4/MKV)) of SolveigMM
By DmitryV in forum EditingReplies: 17Last Post: 20th Oct 2023, 06:47 -
Frame accurate cutting of H.264 files
By Ahari in forum Newbie / General discussionsReplies: 28Last Post: 15th Mar 2014, 21:10 -
Frame accurate WMV edits
By jbeezer in forum EditingReplies: 5Last Post: 5th Jul 2010, 15:41 -
Pioneer 531H
By cscasto in forum DVD & Blu-ray RecordersReplies: 4Last Post: 6th Nov 2008, 21:19 -
SolveigMM Video Splitter 2.0 with MPEG-2 frame accurate editing is out
By DmitryV in forum Latest Video NewsReplies: 4Last Post: 23rd Aug 2008, 06:54
