Auto log on is no longer working for me. I have to enter my details every time I visit the site, which is a bit of a pain. Have flushed my cache and cookies. Anyone else experiensing this problem.
Results 1 to 28 of 28
What browser are you using. Maybe you have set to delete all details (cookies, cache, history etc..) when your browser closes.
Its the same case for me. -
I am using firefox. I have deleted all videohelp cookies. I still have to log on at each visit though
Even if I am logged in, it prompts for my details every time I try and reply to a thread
do you get a &sid=3489032094832984 in the forum links?
try disable the cookies and log in, you should then get links like https://www.videohelp.com/forum/viewtopic.php?t=274053&sid=8462a1315b44aa243232363dc570aaa8. try then reply. does it work?
This ?
https://www.videohelp.com/forum/viewtopic.php?t=274053&sid=3509e58bf169cc55c7c4f0c6d1e06fc7
I have the same problem with IE6. I have to log in at each initial visit although it does not ask for my log in detail for each reply like firefox does. -
Links are getting truncated
do you have some crappy software firewall installed?
I have zonealarm installed, but I have been using that for ages
Cookies disabled
videohelp.com/forum/viewtopic.php?t=274053&sid=9abb9a7e991fcf5cccf5153 e2078de12 -
Cookies enabled
videohelp.com/forum/viewtopic.php?t=274053&sid=c2706bce10a799c4a4202ac f78708f1f -
I just turned off zone alarm and now I am not getting a sid.
But this is what I just got posting that last message
videohelp.com/forum/viewtopic.php?p=1338818&sid=a1c8eb5e76d8bbc6288331 0ead06c73c#1338818 -
Cookies are definately enabled in the browser
I am only getting sid now on replies and auto log in seems to be working again now that I have turned off zone alarm.
login and then try https://www.videohelp.com/forum/test2.php
Turned zonealarm back on and auto login is still working, very strange.
Says cookies enabled
Seems like something may of screwed up in zonealarm, and shutting it down and restarting seems to have sorted it.
It would appear so. Thanks for your help Baldrick. I am actually using a linksys wireless router with built in firewall now so I do wonder if there is any point in using a software firewall. What are your thoughts Baldrick.
I'm not Baldrick, but...
Software firewall: Gives you control over which programs access the internet, give syou control over cookies and stuff (and zonealarm blocks ads, I believe)
Hardware firewall: Gives you control over wich programs access the internet (though much more limited, through port blocking) + blocks incoming ports from attacks
I'd say keep both
EDIT: By "both" I meant both a software and hardware firewall, it doesn't have to be zonealarm-Yar, matey!- -
I'd say get rid of ZoneAlarm....it blocks way too much.
I use Kerio Personal Firewall 2.1.4...the best software firewall, not 304932490 features just a firewall. -
Cheers balders, I will look into that.
thanks as well kingnog
Can not log onto PC
By Noahtuck in forum ComputerReplies: 19Last Post: 12th Dec 2009, 21:35 -
Log in?
By alintatoc in forum ComputerReplies: 10Last Post: 5th May 2009, 01:04 -
Log Me In
By Lucifers_Ghost in forum ComputerReplies: 3Last Post: 6th Jun 2008, 07:02 -
Log in
By MintyJ in forum ffmpegX general discussionReplies: 3Last Post: 15th Mar 2008, 17:18 -
problems converting video with 3GP (error log included)
By Luke Vader in forum DVD RippingReplies: 0Last Post: 17th Dec 2007, 16:20
