I have photoshop and I am attempting my first custom dvd cover. I have an image that is smaller than the dvd case cover (290x397) that looks great at this size but I want to blow it up to fit the cover. Is there a way to do this but still keep the image looking as sharp and clear as it does at its original size?
I also found a cover that is 800x537 with resolution 300x300. Can I enlarge it to 1493x1000 or even 2047x1393 with res 96x96. If so How would I go about changing the WxH and the resolution within photoshop?
What We Do In Life, Echoes In Eternity....
No, but by blowing it up Photoshop will guesstimate what belongs there so it won't look blocky giving you a soft/blurry but non-pixelated image. Once you've blown up you could try applying some more contrast or other filter.Originally Posted by Denvers Dawgs
I don't know how PS works.... so someone else will have to clue you in on that.
Here's alink see my posts with the helmet images: https://www.videohelp.com/forum/viewtopic.php?t=237634 -
There is a program called MultiCoverPrint that prints to the exact size needed. Last I saw it the program was still free. It is all I use to print my covers(though I don't print that many). As long as I have the proportions correct on the original....it doesn't matter....it will print them perfectly.
Uncheck the resample image box. That will only change the resolution and not the actual dimensions of the image. Of course, going below 150 will result in crap but acceptable quality.Originally Posted by Denvers Dawgs
If this was custom, why didn't you start with a huge file to begin with?His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
I don't have a scanner, so I just chose a image of what I wanted from the net. Here is the image I wanted to use...
here is how the front cover came out
Windows7 image backup - restoring the image question
By ranchhand in forum ComputerReplies: 18Last Post: 15th Apr 2012, 08:13 -
Sorry for the Rudimentary Question...DVD image not happening.
By stratojbear in forum DVD & Blu-ray PlayersReplies: 7Last Post: 23rd May 2011, 11:06 -
Printed page image don't equal PC monitor's image?
By bryankendall in forum Newbie / General discussionsReplies: 9Last Post: 11th Nov 2008, 14:45 -
Vegas 8 - replace an image with image from previous frames
By sdsumike619 in forum EditingReplies: 2Last Post: 5th May 2008, 15:26 -
Vegas - add image to video (DVD(mpg)) and moving image around
By psxiso in forum EditingReplies: 4Last Post: 11th Jul 2007, 05:29
