Hello, I have a DVD that is getting kind of scratched up. I wanted to back it up before it was ruined. The DVD still plays fine in my 3 DVD players, and in my computer. However, when I tried using DVD Shrink to back it up, I got a 'cyclic redundancy error,' and when I later tried using DVD XCopy, it also had an error. Is there any way I can back up this DVD? I'm afraid that the kids may ruin this one. Thanks in advance for your advice and help!
Try ripping with dvdfab decrypter.
Donadagohvi (Cherokee for "Until we meet again") -
These errors are usually caused by scratches/damage on the discs.
You can try ripping it with DVDFAB Decrypter as mentioned by freebird or you can also try DVDdecrypter.
If they fail to rip the disc then I would suggest trying to rip from another drive as some drives can be more fussy than others.
I usually rip from my DVD-ROM drive but in the past when I have had problem discs I have found that my DVD writer was able to read the bad sectors better.
Give it a try.
HARRYSPADGE is correct. Try alternative rippers and dvd drives.
Standalone dvd players are better at playing dvds with errors than PC dvd drives. PC dvd drives do more of a bit to bit reading, especially if using a software ripper and therefore are more sensative to errors.
Though the dvd may play fine in your standalones, you could have a problem trying to rip it with any dvd drive. It never hurts to tray anyway. Also, try vobblanker and ISOBuster and give the dvd disc a good clean beforehand.
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 08:58 -
The Dark Knight backup error
By mregee in forum DVD RippingReplies: 15Last Post: 19th Dec 2008, 18:37 -
Error on backup hd-dvd 1.0
By kulmagen in forum DVD RippingReplies: 6Last Post: 7th Feb 2008, 13:08 -
hp dvd 1040i, hp simple backup, error message:sbwin32.exe has generated err
By 84transam in forum DVD & Blu-ray WritersReplies: 4Last Post: 8th Jan 2008, 13:18 -
question about Ghost backup error
By jimdagys in forum ComputerReplies: 7Last Post: 10th Sep 2007, 23:32
