My computer says this.
The USB composite device is a HI-SPEED USB DEVICE and will not function at reduce speed when pluged into a Non HI-SPEED USB DEVICE
Then it says Recommendation
You must add a HI-SPEED USB Host controller to this computer to obtain maximum performance.
So does that mean i can buy something for the laptop??
Results 1 to 27 of 27
Well, maybe. What you need is a card that supports the USB 2.0 spec. Do you have a spare slot in your laptop?
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Ya,
I have 2.
One for my wireless card and one for something else
Can someone please link me to one of these things i need please
I would like a good one thats a good price
thanks -
You're talking about external PCMCIA slots. I'm talking about internal card slots.
While you're at it you might look at some combo cards with USB2 and Firewire. It's more expensive at first, but cheaper in the long run if you ever need Firerwire.
This is just one example:
http://www.firewire-1394.com/ads-usb-2-firewire-cardbus.htm
-drjThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
The 2 slots i have are in the laptop...... Aint that internal?Originally Posted by junkmalle
The PC cards recommended above are what you want. Your laptop has no "internal" support for USB2.
I guess that laptops no longer have internal slots for adding stuff like this. Your only remaining option is to use the external PCMCIA slots.
It will plug into your computer like this:
http://www.cyberiapc.com/classicsys/pics/workpad4.jpg
http://www.rz.fhtw-berlin.de/img/screenshot(400)/rz.web/content/images/Helpcenter/wlan-zugang/pcmcia/pcmcia_01.png -
All right
Thanks everyone
Few more questions
Can i buy one of these at a local bestbuy??
and if i do get this, and seeming the video capture i hvae needs a USB 2.0 will the picture quality be alot better??
Thanks -
Yes.Originally Posted by Bravo568
Better than what? If you're capturing now via USB 1.1 at a low frame size, low frame rate, and/or low bitrate then the switch to USB 2 will allow for larger frame sizes, higher frame rates, and/or higher bitrates -- better captures.Originally Posted by Bravo568 -
All right
Maybe this is the problem cause with the 1.1 the picture quality is REALLY bad.
I hope this will fix the problem
O ya and will something like this http://www.bestbuy.com/site/olspage.jsp?skuId=6307427&type=product&id=1074787928079
Be good? -
Most usb devices are backward compatable to usb 1.1, they just do not give full performance capabilities.
My ADS InstantDvd 2.0 will auto detect if it is pluged into usb 1 or usb2 and limit the capture properties accordingly. With only usb1 I can capture full D1 at up to 4mb/s (which is all I ever use anyway) but will go up to 15 mb/s with usb2
The above assumes that the rest of your system can handle the data flow. Do a bench speed test on your hard drive to determine if it can handle the sustained read/write that you are looking for. For myself, using an older pc or laptop that did not have adequte bus speed I used the ADS IDVD=2 connected to a usb-1 port and captured to an external hard disk keeping my capture bitrate below 4mb/s -
Ok, I really wish i knew what you just said... but i didnt
Ok...
But i just want one, dont i?
I just want a GOOD one that will work my my laptop.
Like the one that i posted, is that a good one?
I need one from a local store like Bestbuy or CompUSA
Cause im not allowed to order from the net.
Thnks -
USB 2.0 is a pretty mature technology. There's not much difference between different brand cards. Just buy a cheap one from a local store -- if it doesn't work you can return it.
Not that PCMCIA is also called PC CARD. -
Yes. Should work fine. You might want to check to see if your wireless card and your new USB 2.0 card will both fit in to the laptop at the same time. Sometimes there is only room for one card at a time, even with two slots. If you don't need to use the wireless card at the same time as the USB, then no problem either way.Originally Posted by Bravo568
Hey,
I just wanna thank u all for helping me. I brought a usb 2.0 bus card thing and it works great.
But i need help with one more thing.
When i plug in my xbox to the caoture thing and put my screen in Full screen it is quit laggy.
Is their anyway i can fix this??
Thanks -
@ brav0568
By "laggy" ..am I correct to assume you mean, "sluggish" performance ??
If this is video capturing, they you are probably out of luck with
performance, because your USB device (that you connected to)
(ie, say it was a capture gizmo) is probably USB 1.x speed.
Getting a USB 2.0 card will not speed up a USB 1.x device.
I have a USB 1.x digital camera that I have been playing with this past
week. I have a USB 1.x/2.x onboard (though, bad performance) and
a dedicated USB 2.0 I/O card I picked up at CompUSA for $39 bucks.
Anyways..
When I connect my device (digital camera) to my USB 2.0 card, it
bumps down to USB 1.x performance. The reason for this, is because
the camera is only capable of 1.x speed. That's it. So, weather
you have 2x, 10x, 1000x USB speed, will not make your (shall I say)
hardware USB device go faster
I'm assuming that your device is USB 1.x, and connected to a USB 2.0
port.
-vhelp 3457 -
Can I guess at your current situation setup ??
You have a USB cam
I'm thinking about checking out a $30 dollar USB cam (to replace
my "free" digital camera) for a USB 2.0 camera. That *should*
give me the speed I am looking for. I'm planning on picking one
up this evening
fwiw.. if intereste, I'll keep you posted of the results. USB
devices should work (performance 'wise) even in laptops too.
-vhelp 3458 -
I think he wants to play games on the XBox through the USB capture device to the laptop monitor. I think he is in big trouble and will be quickly defeated.
Darwin applies to latency too. -
There's no way around the lag between the Xbox and the computer display. The capture device has to capture a full frame before it can send it to the computer. Then the computer probably buffers a few frames before it displays them.
Split the video signal from the Xbox -- run one to the capture box, one to a TV. Play the game on the TV while capturing on the computer. -
Thats what im doing right now, but if i wanna capture the xbox i have to switch it to the other thing...
Whats a good video editing program??
AverTV USB HD DVR or Hauppauge USB HD PVR
By gll99 in forum Capturing and VCRReplies: 34Last Post: 8th Jun 2015, 10:56 -
Which hdtv's have a USB port, so you can plug in a flash drive or USB HDD?
By snafubaby in forum DVB / IPTVReplies: 8Last Post: 30th Nov 2010, 17:03 -
Question about deleting USB drivers to fix lack of USB notification
By jimdagys in forum ComputerReplies: 13Last Post: 15th May 2010, 11:24 -
Cinergy 400 USB & pcmcia»USB 2.0 difficulties
By AEN007 in forum Capturing and VCRReplies: 0Last Post: 4th Mar 2009, 02:21 -
Can a usb mass storage mp3 player and usb harddrive coexist in vista?
By yoda313 in forum Off topicReplies: 3Last Post: 5th Aug 2007, 19:23
