Linear and Non-Linear editing.
Someone more qualified can provide the definition. :P
I'm no expert but here is goes!
Linear: had to do with the actual cutting of film or video tape and splicing the pieces back together. You worked in a linear fashion along the length of the film or tape. The process was "destructive" in that everything you did was permanent. You are creating a final edited film or video from actual physical pieces or clips from your original video or film
Non linear is a non distructive " Virtual " method where you can edit to your hearts content but you are not really affecting or destroying the original source. You are really creating a set of instructions that the NLE applies to create the actual final edited form during output or rendering. Your original clips remain intact and you end up with a 2nd piece of video with all the changes and effects you created during editing.No DVD can withstand the power of DVDShrink along with AnyDVD!
5.1 Hi-Fi Suggestions?
By therock003 in forum AudioReplies: 11Last Post: 8th Dec 2011, 11:19 -
Need some software suggestions
By drtanz in forum EditingReplies: 0Last Post: 29th Nov 2011, 04:18 -
Could the definition for h264 be added to the glossary?
By yoda313 in forum FeedbackReplies: 2Last Post: 27th Jun 2010, 07:50 -
new PC suggestions
By kj1983 in forum ComputerReplies: 9Last Post: 18th Aug 2008, 16:45 -
I need suggestions
By aruwin in forum EditingReplies: 3Last Post: 18th Nov 2007, 04:23
