issue:
i have a CD collection and want to import them into a database on cd pc to be able to print labels
Manually inputting my CDs would be too much work :P So I look for a way to automate this.
I want an applescript (with cocoa app if necessary) which appends info of a move to a text file when a CD is inserted:
so
- look for CDs with 1 big avi
- extract codecs used (this is what I cant get done without opening QT/VLC and playing/opening the movie)
- lookup info on IMDB based on title
- enter info into "database" (could be a text file)
So what Im looking for now is
a) a complete solution (advice appreciated)
b) an automated (non-gui) way to extract codecs used !!!
Thanks for any help,
Regards,
Dominik
Results 1 to 9 of 9
Ok,
I'm not understanding because you are kinda talking about
CDs, wich i assume are Video CDs? or Audio CDs?
and then you switch to talking about AVIs?
If all you want is a way to:
-Catalog your CD collection
-Print label containing all the information stored on the discs
on the label
-A simple few clicks ( and a drag and drop) to catalog
then I would reccommend Disktracker 2.3 from Portents,
avaialble here.
You can with it:
create a catalog, drag and drop the disk onto the catalog,
it will scan it, give you a complete listing of what's on it,
and then you can print a label for the cd with that info
on it.
If you want to know what codecs are used on each file
of an avi, and create a database of that, well AFAIK,
that still is a (somewhat) manual labor process.
Informator may be a way, Grabby MP maybe another,
but both cost $$$ so I really don't know...."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
I don't know of any complete solution, but your b):
ffmpeg -i /path/to/file
(note that this will case an applescript error because ffmpeg wants to convert out to something, so it errors, and so will your applescript. You can write it out a text file and read that in - something like "ffmpeg -i /path/to/file &> ~/Desktop/vidEval.txt") ffmpeg is available embedded in a lot of shareware products - you can use those binaries easily to do it. You'll get something like this:
Input #0, avi, from '/path/to/file':
Duration: 00:25:37.8, start: 0.000000, bitrate: 1068 kb/s
Stream #0.0: Video: mpeg4, yuv420p, 352x288, 25.00 fps
Stream #0.1: Audio: mp3, 44100 Hz, stereo, 111 kb/s
The other program that would work is tcprobe (part of transcode - I don't think its available in pre-compiled form, but I compile from source, so I don't really search out for it):
tcprobe -i /path/to/file
[tcprobe] RIFF data, AVI video
[avilib] V: 25.000 fps, codec=DX50, frames=38445, width=352, height=288
[avilib] A: 44100 Hz, format=0x55, bits=0, channels=2, bitrate=111 kbps,
[avilib] 38102 chunks, 21337120 bytes, CBR
[tcprobe] summary for /path/to/file, (*) = not default, 0 = not detected
import frame size: -g 352x288 [720x576] (*)
frame rate: -f 25.000 [25.000] frc=3
audio track: -a 0 [0] -e 44100,0,2 [48000,16,2] -n 0x55 [0x2000] (*)
bitrate=111 kbps
length: 38445 frames, frame_time=40 msec, duration=0:25:37.800
(where 0x55 actually represents which audio codec is used - which must be mp3)
You can see from the above examples: ffmpeg makes the video codec a generic mpeg4 (DX50 is a divx 5 codec), whereas you'd have to convert 0x55 (I think the others are 0x20 for aac and 0x50 for mp2) with tcprobe. Any attempt I made to use mplayer or VLC to get the info caused the file to actually start playing, but I didn't try to hard either; mencoder happily started to convert to my $HOME folder. -
I think there may be another shortcut. You use ffmpeg to get at the audio codec. That's relatively easy. Comes ready to use after you parse it out.
You can do this to get at the video codec with nothing readily available: "head -1 /path/to.avi" in Terminal.app, and you'll see all kinds of ugliness, but you can parse it out. This command isn't perfect (it butchered 1 file as lhXV), but if you chop off the last part of the command then you can use Applescript's:
ignoring case
if some_thing contains "xvid" then --matches "XviD", "lhxviDJUNK"...
set my_codec to "xvid"
else if (some_thing starts with "DX") or (some_thing contains "DX") then
set my_codec to "divx"
end if
end ignoring
here is the heinous shell script:
head -1 /path/to.avi | tr -cd "[:alnum:]" | awk -F "strf" '{print $2}' | sed 's/^[0123456789]//g' | awk -F "LIST" '{ print $1}' | colrm 5 -1
Note: you'll have to escape the quotes in applescript when you try to "do shell script" on that line.
It's still not easy, but you'll eventually pick up the knack. -
ok. had exams last week so couldn't test it before.
Now that I did serveral problems arose:
a) ffmpeg does not write the info to file using the > "file":
It does write its version number etc. but the info about the file is just on the console (using build from ffmpegX)
b) the head | sed command also fails as it does not print either DX or XVID - it shows 0XVI so maybe it is just the offset?
thanksreally appreciate the help!
look for "bunch of output" http://developer.apple.com/technotes/tn2002/tn2065.html
no, I said to leave off the last bit (so drop the colrm 5 -1). okay, so try transcode - seems that ffmpegX has a pre-compiled tcprobe binary inside. You can use:
/path/to/transcode -i /path/to.avi -
thanks got it all working now!
I wrote an applescript to run as a folder action and detect codecs/title of avis on cds inserted.
The question is: can In which 'DVD database software' can I easily import it? (Any recomendations on this would be awesome, too. It should offer IMDB lookup and custom fields AND !export as CSV to be able to print using neooffice/j.)
Thanks,
Dominik
Need basic info on Simple profiles when capturing video with XviD codec
By snafubaby in forum Capturing and VCRReplies: 1Last Post: 19th Mar 2011, 21:54 -
Mediainfo File Info tool "Format Profile" wrong info problem
By dabas in forum Newbie / General discussionsReplies: 2Last Post: 9th Mar 2010, 05:07 -
Codec info
By stigslim in forum Software PlayingReplies: 3Last Post: 11th Feb 2009, 03:33 -
xbox360 won't play this avi,, codec info inside
By sance in forum Media Center PC / MediaCentersReplies: 11Last Post: 24th Dec 2008, 12:11 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 09:41
