Ran DVDFab Decrypter to successfully pull some files off a DVD my daughter had scratched, and that I assume isn't much longer for this world. So I now have a directory of VOb and IFO files. However, I want to convert to MPEG-2 files to playback on the computer (since I'm trying to get away from physical media in the hands of children).
So, I use the Source Wizard in TMPGEnc 3.0 XPress and tell it DVD import, and it complains about the audio format used being incompatible. I try to play the scene in the edit screen, and sure enough, no sound.
I then try using VirtualDubMod, which imports, but again a quick playback in the tool has no sound. I then play using my software DVD player set to that directory, and it works fine.
I'm guessing there's an easy step here I'm missing, but would appreciate a pointer to the nose I can't seem to find on my face.
TIA!
My bad for not being more informative. My Video Out from my computer is my Hauppauge PVR-350 card (on the connected TV), and the other way I serve video is through a MediaMVP in the other room. Both of those require MPEG-2 as input.
Yes, I can successfully playback the VOBs using a number of DVD programs (Intervideo came on the box, so that's what I usually use). Unfortunately, that doesn't work for the other places I'd like to be able to watch from. Hence the original question.
One thing I was able to get working (but hope it isn't the final answer) was to use VirtualDubMod to create a DiVX of the video, and then use TMPGEnc 3.0 XPress to convert that to an MPEG-2. But that adds an extra step that is more work, and I'm concerned a bit about what that might be doing to the image quality as well.
Any more direct way to get where I'm going?
Thanks again,
Ewan -
That led to the thread I needed.Originally Posted by Baldrick
One related question, does the DVDFab Decrypter tool have a similar option, or only the older DVD Decrypter tool?
Thanks again,
Ewan
uploading multpile files in one sitting ? ... [gave up on]
By vhelp in forum FeedbackReplies: 0Last Post: 18th Jan 2010, 18:37 -
How to rotate a MOV file? I just gave up.
By Pixelrage in forum EditingReplies: 10Last Post: 28th Oct 2009, 23:30 -
what do I do with the vobs from dvdfab?
By pattirose in forum Newbie / General discussionsReplies: 3Last Post: 17th May 2009, 21:12 -
Why is an 1100 bitrate giving me a 6.5gb file when before it gave me 1.1gb?
By happyprozak in forum Blu-ray RippingReplies: 1Last Post: 27th Nov 2008, 14:10 -
Convert non-compliant VOBs to "good VOBs"
By pmolson in forum Video ConversionReplies: 3Last Post: 24th Oct 2008, 11:52
