I have a ricoh dvd drive that can't read dvd_vr format disc that I record from my dvd recorder I want to buy a new drive I hear that Plextor supports dvd_vr format i want to make copies of my recorded dvd_vr's but ny drive does not read this format please help guys.
Have you finalised the disc ? If not try finalising it, then maybe your drive will read the disc.
Are you able to see the files on your discs using windows explorer ?
If so I dont believe you need a new drive but instead you may need to convert your DVD_VR discs to VOB format.
The DVD_VR discs are written in a VRO format which many DVD players do not recognise unless they are recorders.
You need to convert the VRO files to VOB format for other DVD players to be able to read them.
Instead of recording in the VR format you could use the VIDEO format which will write the discs in a VOB format so you dont have to convert them at a later time, this way you can copy them without any problems.
Do a SEARCH on VRO and you will see there are several posts about this subject.
I know this because I recently discovered this when trying to copy some of my recorded discs in the DVD_VR format.
Take a look at this post, it may be of some use,
https://www.videohelp.com/forum/viewtopic.php?t=264924&start=0&postdays=0&postorder=asc&highlight=
Recover Semi Dead Hard Drive
By imdaman in forum ComputerReplies: 7Last Post: 11th Jan 2011, 11:30 -
Erase Dead Hard Drive?
By imdaman in forum ComputerReplies: 10Last Post: 25th Dec 2010, 03:06 -
ADVICE: Turning in dead cable modem
By Frank-0-Video in forum ComputerReplies: 6Last Post: 15th Mar 2010, 10:57 -
External Hard Drive - Dead! - Need advice
By pooty13901 in forum ComputerReplies: 7Last Post: 20th Sep 2007, 19:07 -
slave drive seems dead, but cannot boot without it
By ted demen in forum ComputerReplies: 11Last Post: 13th Jun 2007, 08:54
