I've got a AVI with unsynced audio. I tried sync hole to no avail. Is there anything short of re-encoding it to DV and doing it in iMovie?
TIA
You should run your avi through DivXDoctor to create a .mov file before using Sync Hole. Hang on to that original Avi though just in case.
In Sync Hole, start by using the match tracks feature.
Alph
Audio Syncing Issues
By Alexstarfire in forum AudioReplies: 6Last Post: 4th Jul 2010, 03:49 -
Syncing and adding to audio?
By architectofpain in forum AudioReplies: 2Last Post: 20th Jun 2009, 02:03 -
Audio Syncing issue
By jmclean69 in forum DVD RippingReplies: 15Last Post: 4th Feb 2009, 15:34 -
audio syncing
By projecttemp in forum AudioReplies: 3Last Post: 9th Apr 2008, 21:11 -
audio syncing issues
By anap in forum Newbie / General discussionsReplies: 2Last Post: 19th Dec 2007, 04:11
