I am currently using "DivX to DVD Converter" to encode some non-dvd movies into DVD, but I was trying to fit the whole series of Samurai Champloo onto one DVD and it didn't fit.
I tried just deleting some of the VTS videos (along with their .ifo and .bup files) to put only a certain amount of episodes on each DVD. It worked with episodes 1-9, but with 10-19, Nero Burning ROM kept encountering errors (I messed 3 DVDs up b/c of that!). Do I have to change the MAIN "VIDEO_TS.BUP" and VIDEO_TS.IFO" files so that they only say for example episodes 10-19 are on them? I think that's what messing up the burning process; an allocation problem.
Can someone please help with this? Thanks.
You won't be able to stuff 26 eps onto 1 DVD. Not with quality and DVD compliance, at least.
You merely need to extract the files you want, then re-author a new disc.Want my help? Ask here! (not via PM!)
How do I make .bup and .ifo files?
By showmi in forum Newbie / General discussionsReplies: 26Last Post: 3rd Apr 2015, 19:00 -
Burn - VOB without IFO & BUP files?
By Miss Sherlock in forum Authoring (DVD)Replies: 25Last Post: 24th Aug 2009, 01:20 -
Question for .Bup & .Ifo files..
By Pleochoric in forum Authoring (DVD)Replies: 4Last Post: 31st Oct 2008, 06:33 -
How to play a .vob .bup .ifo files?
By Kinstonian in forum Software PlayingReplies: 12Last Post: 19th Mar 2008, 17:26 -
Padding IFO/BUP files to 32kb in OS X?
By Cyrax9 in forum MacReplies: 3Last Post: 14th Jun 2007, 16:46
