  1. Chris,
    Using the lates downloadable build from the Registered User's area I get the following error on startup:
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.ArgumentOutOfRangeException: Specified argument was out of the range of valid values.
    Parameter name: Index was out of range. Must be non-negative and less than the size of the collection.
    at System.Collections.CollectionBase.System.Collectio ns.IList.get_Item(Int32 index)
    at DevComponents.DotNetBar.SubItemsCollection.get_Ite m(String name)
    at x3284ccece41ee22b.x210ff09a2516b1a7.x4e0e7161eb7bf 37d(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
    at System.Windows.Forms.Timer.OnTick(EventArgs e)
    at System.Windows.Forms.Timer.Callback(IntPtr hWnd, Int32 msg, IntPtr idEvent, IntPtr dwTime)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 1.0.5000.0
    Win32 Version: 1.1.4322.2032
    CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
    SVCD2DVD
    Assembly Version: 2.0.2012.19550
    Win32 Version: 2.0.2012.19550
    CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/SVCD2DVD.exe
    CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
    System
    CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
    System.Drawing
    CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
    Assembly Version: 4.9.6.0
    Win32 Version: 4.8.1.0
    CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/DevComponents.DotNetBar.DLL
    AxInterop.CodeLock
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/AxInterop.CodeLock.DLL
    System.Xml
    CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
    System.Design
    CodeBase: file:///c:/windows/assembly/gac/system.design/1.0.5000.0__b03f5f7f11d50a3a/system.design.dll
    Accessibility
    Win32 Version: 1.1.4322.573
    CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
    Interop.CodeLock
    CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/Interop.CodeLock.DLL
    Interop.QuartzTypeLib
    CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/Interop.QuartzTypeLib.DLL
    Interop.DexterLib
    CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/Interop.DexterLib.DLL
    ************** JIT Debugging **************
    To enable just in time (JIT) debugging, the config file for this
    application or machine (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the machine
    rather than being handled by this dialog.
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Please see https://www.videohelp.com/forum/viewtopic.php?p=1333951#1333951
    That will resolve it. Sorry that i didn't mention this to those that did the testing for me!
  3. Thanks.
    Actually I had read that thread before, but with so many installs/uninstalls I had forgotten the significance.
    Working fine now (of course).
