My webcam is suppose to broadcast at 30fps yet the webcast is jerky, as most are. The NTSC standard is is 29.97FPS and i see no jerkyness in broadsast TV.
1.Can anyone explain why that is?
2.how one can measure their webcam FPS rate?
3. any solutions to alllivate the jerky webcast?
It was mentioned here that webcam can only 'push' 10FPS, but that statement was not expounded. Thanks in advance. I'm new to this board and searched the post for associated answers and found none, prior to asking the question.
I'm running DSL through AMD Athlon 2500 with a video card.
Most likely it's a limitation of your upload connection speed. Less frames mean less data it needs to send. If you using a high quality setting that can affect the framerate as well. Consider this....Originally Posted by jmarkos
Average Data Rates
Dial up (upload): 33kbps
Cable (upload): 400-800kbps
DVD : 6000-8000kbps
DV-AVI: 30000kbps
Uncompressed AVI: Astronomical
You can check your connection speed here: http://www.speakeasy.net/speedtest/ -
My webcam is suppose to broadcast at 30fps yet the webcast is jerky, as most are.- I do agree. One interesting note here: 30 FPS is the PAL-M frame rate that is used by the ingenious PAL Brazilian System for public and cable broadcasting. Even though being very compatible to NTSC because it runs at 30 FPS (NTSC is 29.97), PAL-M (the M comes from NTSC) uses PAL color palette to correct the famous never the same color.Most likely it's a limitation of your upload connection speed.
Is your webcam a USB2 or 1, that makes a lot of difference. Also that 30FPS frame rate is for the smallest size picture.
DVDSubEdit error. 30fps instead of 29.97 for SRTs
By cal_tony in forum SubtitleReplies: 3Last Post: 12th Apr 2012, 21:59 -
30fps --> 24fps WITHOUT pulldown
By agni451 in forum Video ConversionReplies: 4Last Post: 4th Apr 2012, 23:25 -
30fps VS 29.970fps
By bdr13278 in forum EditingReplies: 3Last Post: 18th Aug 2009, 19:10 -
Converting 30fps to 29.97fps ?
By blewyn in forum Video ConversionReplies: 2Last Post: 19th Mar 2008, 11:24 -
Converting from 120fps to 30fps
By shorto in forum Video ConversionReplies: 6Last Post: 22nd Feb 2008, 12:51
